WJ Grand Cherokee Jeep Registry
Previous Jeep WJ Grand Cherokee Next Jeep
WJ Grand Cherokee
Email Bookmark Print
plakaaa
New York
Jeep Information
Year:2001
Model:Grand Cherokee
Engine:4.0
Transmission:Automatic
Hello Everyone,
My name is Alex. I recently purchased a 2001 Grand Cherokee Laredo with 32K Miles on it. Everything runs really smooth except I have one small minor issue. Every 10-15 days I have to add antifreeze to the reservoir because it goes to low. No antifreeze drips on the floor, the engine is completely dry, the oil is clean from antifreeze. I changed the radiator cap in the process.
I brought the Jeep to get checked out to a local mechanic. He could not find anything but after I left, about a half hour later, the Jeep overheated for the FIRST time ever and I had the Jeep for about 6 months now. I called him and he mentioned it might be the thermostat that caused it to overheat.
Can someone please give me some help.
Thank you for your time.
None
Login Or Register To Post Comments
shanek26
View shanek26's Jeep
09-14-2020, 03:09 PM
Originally Posted by plakaaa View Post
Hello Everyone,
Try testing the cooling system for combustion gasses. Although the vehicle is extremely low mileage it is still possible that a head gasket is beginning to fail. You can do this test with this tool: Lisle 75500
This will show you if there is an issue with either the gasket or the block/head even if the coolant is not mixing with the oil.
shanek26
09-14-2020, 03:13 PM
Hello Everyone,
Also get yourself an infrared gun and check the radiator for cold spots at operating temp, this would indicate a blockage of some kind.
Hope those tips help, best of luck to you.
