Steering Damper Installation Issue Jeep Registry
Previous Jeep WJ Grand Cherokee Next Jeep
Email Bookmark Print
Jeepnubz
Jeep Information
Hey there, I bought and installed a new monroe stabilizer last night. The issue is that on the axle side I accidentally over torqued the bolt. I was installing it in bad lighting conditions and was only relying on my torque wrench. I think l I got to 60 ft lbs and stopped. I looked at the bushing and the bracket and they looked severely overtightened. I thought somehow my wrench got out of spec and needed calibrating. After I got the other side hooked up, I realized that I had cleaned the bolt with WD40 which probably threw the torque spec off since 65 ft lbs is the dry torque rating. So I backed off the bolt and torqued it to about 44ft lbs instead. Look at the before and after pics.
My questions are: 1) Can I leave it like this or should I take it off and try to somehow reshape the bracket back to where it used to be? 2) Will leaving it like this affect the performance at all?Attachment 3906589Attachment 3906587
None
