Replaced IAC and TPS now have high idle CEL Jeep Registry
Previous Jeep ZJ Grand Cherokee Next Jeep
Email Bookmark Print
jeepjeep523
monroe twp
Jeep Information
So the rpms would surge occasionally in park so I took out the IAC and replaced that and the tps. The problem now is that it's at a constant high idle and the CEL came on. I'll read the code later tonight but it also sounds like intake hose from the air filter is sucking way more air in than normal. took the battery and removed the cables and switched the headlight on and off trying to reset it but still has the same issue. All the parts were OEM. Any ideas??
None
