Jeep Comanche Jeep Registry
Previous Jeep MJ Comanche Next Jeep
Jeep Comanche
Email Bookmark Print
JeepinJunk
Jeep Information
Year:1988
Model:Shortbed
Engine:4.0
Transmission:AW4
Transfer Case:Unfortunately, it is still 2wd
Front Axle:Dana 30
Rear Axle:Dana 35
Axle Gear Ratio:3.54
Suspension:6" lift
Tires:31s
Wheels:15"
Armor:Monkey Bars Off-road rockers
I have owned over a half dozen XJs in the past twenty years and came across this MJ while we were buying a house. I used the "we need a pickup truck" to leverage my wife into letting us buy it. It is a restore while we drive it project. The previous owner had started the 4x4 conversion on it and I just picked up a 1996 XJ to finish the swap over. The plan is to swap the entire power train over for some power and swap in an 8.8 I have acquired. I am going to de-lift it down to about 3" and trim the fenders enough to let me run some 33"-35" tires. The front will be a Clayton 3 link with some 3" OME coils and the rear will have the bolt on spring over kit removed and some new 3" lift leaf springs and longer shackles installed in its place.
None
Login Or Register To Post Comments
