Green Xj Jeep Registry
Previous Jeep XJ Cherokee Next Jeep
Green Xj
Email Bookmark Print
shuazien
Jeep Information
Year:1999
Model:Cherokee Sport
Engine:4.0 Litre AMC 242
Transmission:Aisin-Warner AW-4 four-speed automatic
Transfer Case:New Process NP231 Command-Trac
Front Axle:Dana 30, high pinion, reverse cut, 297x/760 universal joint, 27-spline axle shafts
Rear Axle:Chrysler 8.25", c-clip, non-ABS, 29-spline axle shafts
Axle Gear Ratio:3.73:1
Suspension:Front: Rough Country 4.5" lift, Rear: ProComp 3.5" Leaf Springs with Rough Country adjustable lift shackleings with Rough Country
Tires:Achilles Desert Hawk X-MT 32 X 11.50 X 15
Wheels:'97-'01 OEM Wrangle 5 Spoke wheels
Armor:N/A
Recovery Gear:Tow Strap, Recover Rope, Tree Saver, Chain Saw, Shovel
Accessories:N/A
Future Modifications:Unibody Stiffiners, Recover Hooks, Long Arm Conversion, Rock Rails, Winch w/Bumper, Rear Tire Carrier w/Bumper
First Jeep
Bought with the lift kit and tires freshly installed. I swapped in the new rear springs to replace the saggy old springs with an add-a-leaf. Disconnected front sway bar.
Currently trimming the fenders and bumper caps for more tire clearance.
Also currently tracking down issue with Head lights...
None
Login Or Register To Post Comments
