windshield light mount install help - JeepForum.com
post #1 of 6 Old 04-07-2010, 03:59 PM Thread Starter
HighRoller02TJ
im trying to install my windshield light mounts but i cant get the torx screws in the front off, feels like its welded on. stripped one side a bit. any tips? i dont wanna break the winshield by using a hammer to loosen it up
HighRoller02TJ is offline
post #2 of 6 Old 04-07-2010, 04:10 PM Thread Starter
HighRoller02TJ
maybe just use the 3 side bolts, put some double sided tape up front, some light wieght lights and call it a day lol
post #3 of 6 Old 04-07-2010, 07:42 PM
gmgreen
1983 CJ7
I just installed KC brackets on my Jeep. The drivers side wasn't so bad but the pass side was. I sprayed a little liquid wrench on them and let it sit overnight and they came right out.
gmgreen is offline
post #4 of 6 Old 04-07-2010, 08:19 PM
Camo Deere
Camo Deere's Avatar
We stripped about 4 of them, just put electrical tape over the empty holes, had to drill them out
It's a PITA, mine were pretty bad
Camo Deere is offline
post #5 of 6 Old 04-08-2010, 02:06 PM Thread Starter
HighRoller02TJ
im an electrician so the electrical tape idea works for me
post #6 of 6 Old 04-09-2010, 08:39 AM
Faramir66103
I'd heard so many horror stories about those bolts that I went to Sears and got an impact driver since I don't have an air or electric impact wrench. I triple checked that I had the correct size torx bit by trying the next size up as well. That's something I always do with torx because they can be so deceiving and easy to strip. All of the driver's side bolts on my '99 came free with just a standard ratchet, but the passenger's side bolts all needed the impact driver. I found that they all had some amount of threadlocker, so I was also prepared with a torch to apply a bit of heat if absolutely necessary, but fortunately, the impact driver broke them all free. When I put them back in I applied a bit of anti-seize on them as well so they hopefully won't be so troublesome in the future.
HTH,
Adam
'99 TJ Sport, 4.0 I6, 5 speed manual transmission, Hi Lift w/offroad kit, Viair 450C compressor, Garmin GPS, Skid Row Engine/Transmission, steering box & radiator skid plates, Kilby gas tank plate, AtoZ Fab full length rocker guards, Performance Accessories 1" Body Lift, OME 2.5" HD springs & shocks, JKS trackbars front & rear, BFG AT 33x12.5r15, EBC Yellow pads and Centric rotors
Faramir66103 is offline
help w/ spot light windshield mount jaspepp Audio, CB & Ham Radios, GPS, & Electrical 4 02-12-2009 04:11 PM
Need Windshield Light Mount Wiring help dukeearl10 Audio, CB & Ham Radios, GPS, & Electrical 1 08-25-2008 06:48 PM
windshield light mount bracket wiring` Trebor Audio, CB & Ham Radios, GPS, & Electrical 1 01-21-2008 10:20 PM
Windshield light bracket as antenna mount? amper Audio, CB & Ham Radios, GPS, & Electrical 7 06-07-2007 11:56 AM
KC windshield light mount? - TJ nikki Audio, CB & Ham Radios, GPS, & Electrical 0 04-15-2005 10:12 AM
