Winch wire route - JeepForum.com
post #1 of 14 Old 05-12-2014, 02:22 PM Thread Starter
Airborne Lee
Airborne Lee's Avatar
Winch wire route
What is the best wire route for my new Quadratec 9500si winch? All routes leave the back wire lead short 10 inches.
'16 JKU Rubicon, Tan, RR Front Bumper, 9500i, Atlas Rear w/Tire Carrier M416 Trailer
Airborne Lee is offline
post #2 of 14 Old 05-12-2014, 03:12 PM
RockyClymer
RockyClymer's Avatar
Not sure about 2013, but in my 08 I ran them through the grill, up by the air intake, and then along the passenger side of the engine compartment to the battery.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 14 Old 05-12-2014, 03:22 PM Thread Starter
Airborne Lee
tried that. they are a foot short. the only way i could get them to reach is straight up beside the radiator over the air filter box between the engine and the fuse box.
post #4 of 14 Old 05-12-2014, 04:50 PM
MyJKU14
MyJKU14's Avatar
2014 JK Wrangler
That's weird. I would call them up maybe and see which way they recommend routing it?
'14 JKU
'05 LJ Rubicon (husband's)
Colorado Jeep Club #281
Past Jeeps: '02 WJ Overland, '02 WJ Limited, '08 KK Sport
MyJKU14 is offline
post #5 of 14 Old 05-12-2014, 07:06 PM
TheBoss
TheBoss's Avatar
Use a quick disconnect in line with the battery. Buy a couple of feet of pos and neg cable and you will be good to go. This way there will be no accidental draw or unintended misuse of the winch. I routed mine as rocky clymer did and added an abrasion guard sleeve like they use on hydraulic lines to eliminate any risk of shorting out the wires.
TheBoss is offline
post #6 of 14 Old 05-12-2014, 07:48 PM
CJ7nvrstk
CJ7nvrstk's Avatar
This, and I even had extra cable but my winch is an Engo.
RED Friday. Remember Everyone Deployed
45 MB, 67 Commando, 85 CJ, 08 JKU, 11 JKU
CJ7nvrstk is offline
post #7 of 14 Old 05-12-2014, 07:52 PM
SubAtomicGenius
SubAtomicGenius's Avatar
2011 JK Wrangler
I upgraded the cables to #1 welding wire, copper lugs, quick disconnects, and fused positive. Better for hard pulls. Interesting, but stock winch cables dont meet electrical codes for their amperage draw... Suppose it is rated for intermittent duty...
SubAtomicGenius is offline
post #8 of 14 Old 05-13-2014, 10:51 AM Thread Starter
Airborne Lee
Great idea, can't believe i didn't think of that. any links for disconnects? Did you do both pos and neg? or just one, which one?
I thought about changing the battery terminals also but the factory is crimped and there is an extra post that I am using. thoughts?
post #9 of 14 Old 05-13-2014, 11:12 AM Thread Starter
Airborne Lee
what do you guys think of this:
Fuse:
http://www.amazon.com/Scoshe-EWFH-Si...productDetails
Disco:
http://www.wirthco.com/rotary-dial-d...-switches.html
Disco:
http://www.amazon.com/Volt-Battery-D.../dp/B007O0BBFM
post #10 of 14 Old 05-13-2014, 02:11 PM
PhatBasturd
PhatBasturd's Avatar
2010 JK Wrangler
I went the same route as SubAtomic using 2/0 welding wire.
Pics are examples of what I used:
TemCo 2/0 welding wire (eBay):
Anderson 350 AMP quick disconnects:
VTE Warehouse Hi amp ANL fuse holder with cover:
Name:  ANL Hi Amp Fuse Holder.jpg
Size:  8.5 KB Name:  ANL Hi Amp Fuse Holder w-cover.jpg
VTE Warehouse 400a ANL fuse:
Name:  anl ceramic fuse - Google Search - Internet Explorer_2014-05-13_13-54-05.jpg
In the process of replacing/re-wiring battery terminals with this type of "military" terminal (delcity.net):
Name:  military battery terminal - Google Search - Internet Explorer_2014-05-13_13-59-41.jpg
Size:  11.2 KB Name:  military battery terminal - Google Search - Internet Explorer_2014-05-13_14-01-13.jpg
PhatBasturd is offline
post #11 of 14 Old 05-13-2014, 02:58 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Attachment 1336921
Attachment 1336689
Attachment 1336713 Attachment 1336721
Attachment 1336777
Attachment 1336889 Attachment 1336897
That's what I'm doing with mine (though my yj battery is easier to access). I used these battery terminals and instead of just a single quick connect, add jumper cables to the second connector and mount it on the bumper. A pic of my marine terminals
Luck Favours The Prepared
Anticanman is offline
post #12 of 14 Old 05-13-2014, 04:37 PM
RockyClymer
I used the Anderson 350 amp disconnect also so that there was no "accident" and also placed the positive lead in one of the plastic wire looms for some extra abrasion resistance. So far, no problem. Even though the APP is rated at 350 amps, the know that at max draw the M8000 is close to 400 amps, but usually intermittent.
NRA Life member
post #13 of 14 Old 03-15-2016, 10:44 PM
catang5oh
2016 JK Wrangler
I also took another quick disconnect and put it on my heavy duty jumper cables, no more raising hood to jump somebody. Just unplug winch and plug in jumper cables.
catang5oh is offline
post #14 of 14 Old 03-15-2016, 11:09 PM
1222
RIP John
1222's Avatar
Moved from JK tech forum
(2011-2016)
1222 is offline
