Winch/Transmission question - JeepForum.com
post #1 of 7 Old 05-11-2010, 05:02 PM Thread Starter
Paratrewpr
Paratrewpr's Avatar
2010 JK Wrangler
The other day I was talking to my dad about the new winch I got. He used to work at a phosphate mine where they were always pulling something or other around with a winch. He asked me if I was aware of how having 10k pounds of force pulling against the transmission would affect the trans. As this is the first time I've owned a winch, I hadn't thought about it before.
So... I think I need a winch 101 class and I'm going to hit up my local clubs to see if they can provide some real world training but, for now I gotta know... is it inappropriate to pull something (say tree stump) from a parked vehicle (either auto in park or manual with gears engaged)? Is it harmful to the transmission?
Thanks
Paratrewpr is offline
post #2 of 7 Old 05-11-2010, 05:46 PM
wushaw
Rockin jeep
wushaw's Avatar
Use the parking brake, chocks and put it in neutral.
wushaw is offline
post #3 of 7 Old 05-11-2010, 05:48 PM
greensaharatj
greensaharatj's Avatar
Just don't put it in park (auto) or in gear (manual) and you should be fine
2003 Jeep TJ w/RC 3.25 lift rockin 35x12.50r15 Dunlop Mud Rovers on Crager Soft 8's, Currie HD Steering system, Delta Quad-Bar headlights, KC 55watt fogs, 130watt long range KC daylighters on the windshield, Smittybilt Tube Fenders, Smittybilt X20 10k Winch, Poison Spyder front Stinger--future stuff, SYE/CV Driveshaft, Rear corner armor, Engine/Oil skid, Tummy Tuck
Don't forget to wave :wave:
greensaharatj is offline
post #4 of 7 Old 05-11-2010, 07:23 PM
notmyj
notmyj's Avatar
You want to put as little stress on the drivetrain as possible either by holding the brake pedal, or by tieing off to an anchor. Usually, if I am dragging logs up the side of the mountain at camp, I will tie off to a tree, block the tires and leave it in neutral. If there is nothing to tie off to I will hold the brake, or have someone else hold the brake while I winch.
I have plans to install a winch brake that uses the service brake.
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
post #5 of 7 Old 05-11-2010, 09:26 PM Thread Starter
Paratrewpr
Paratrewpr's Avatar
2010 JK Wrangler
Good info yall. Thanks
post #6 of 7 Old 05-11-2010, 09:40 PM
ritjobbie
ritjobbie's Avatar
Personally, I always winch with the engine running. If I'm the stationary object in the equation (me pulling something) I'll be in neutral standing on the brakes with a light food on the gas keeping the revs up a bit. Always in neutral.
1995 YJ Rio Grande, 2.5L Low Output Engine
ritjobbie is offline
post #7 of 7 Old 05-12-2010, 12:06 AM
notmyj
notmyj's Avatar
Yeah always keep the engine running when ever possible. I have a hydraulic winch so i dont need to bring the engine speed up as the pump makes the ample flow at idle to drag logs and such. But even electric guys should keep it running at a high idle (aka 1000-1400 RPM) so the alternator can produce the power needed to take most if not all the load off of the battery.
notmyj is offline
Question about winch buying winch for front bumper jeep53191 General Jeep & Off-Road Equipment 0 10-07-2009 08:30 PM
winch question rob40wilson03 General Jeep & Off-Road Equipment 11 03-24-2009 04:03 PM
8,000 lb vs 10,000 lb winch question SecondTJ General Jeep & Off-Road Equipment 9 02-18-2008 10:47 AM
Winch question on my tj Arron General Jeep & Off-Road Equipment 2 05-29-2007 12:11 AM
winch question JeepMKcomin General Jeep & Off-Road Equipment 3 09-18-2006 04:02 PM
