JeepForum.com (https://www.jeepforum.com/forum/)
-   General Jeep & Off-Road Equipment (https://www.jeepforum.com/forum/f27/)
-   -   Winch/Transmission question (https://www.jeepforum.com/forum/f27/winch-transmission-question-1030338/)
Paratrewpr 05-11-2010 05:02 PM
The other day I was talking to my dad about the new winch I got. He used to work at a phosphate mine where they were always pulling something or other around with a winch. He asked me if I was aware of how having 10k pounds of force pulling against the transmission would affect the trans. As this is the first time I've owned a winch, I hadn't thought about it before.
So... I think I need a winch 101 class and I'm going to hit up my local clubs to see if they can provide some real world training but, for now I gotta know... is it inappropriate to pull something (say tree stump) from a parked vehicle (either auto in park or manual with gears engaged)? Is it harmful to the transmission?
Thanks
wushaw 05-11-2010 05:46 PM
Use the parking brake, chocks and put it in neutral.
greensaharatj 05-11-2010 05:48 PM
Just don't put it in park (auto) or in gear (manual) and you should be fine
notmyj 05-11-2010 07:23 PM
You want to put as little stress on the drivetrain as possible either by holding the brake pedal, or by tieing off to an anchor. Usually, if I am dragging logs up the side of the mountain at camp, I will tie off to a tree, block the tires and leave it in neutral. If there is nothing to tie off to I will hold the brake, or have someone else hold the brake while I winch.
I have plans to install a winch brake that uses the service brake.
Paratrewpr 05-11-2010 09:26 PM
Good info yall. Thanks
ritjobbie 05-11-2010 09:40 PM
Personally, I always winch with the engine running. If I'm the stationary object in the equation (me pulling something) I'll be in neutral standing on the brakes with a light food on the gas keeping the revs up a bit. Always in neutral.
notmyj 05-12-2010 12:06 AM
Yeah always keep the engine running when ever possible. I have a hydraulic winch so i dont need to bring the engine speed up as the pump makes the ample flow at idle to drag logs and such. But even electric guys should keep it running at a high idle (aka 1000-1400 RPM) so the alternator can produce the power needed to take most if not all the load off of the battery.
The time now is 12:45 AM.
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
