Winch question on my tj - JeepForum.com
post #1 of 3 Old 05-28-2007, 09:19 PM Thread Starter
Arron
I bought a used winch (warn M8000) and i got a hell of a deal on it so i cant complain too much but it wont spool outward. It winches just fine pulling in as we found out the other day when a friend flipped his jeep on its side four wheeling. We had to winch it back over but when we noticed the winch cable was tangled up in the door pin and tried letting it back down it wouldnt. The solenoid clicks but nothing happens.
What could be wrong with it?
Arron is offline
post #2 of 3 Old 05-28-2007, 09:37 PM
SlinkyTJ
This space for rent.
SlinkyTJ's Avatar
2009 JK Wrangler
Bad solenoid. I think they are fairly easy to replace but couldn't tell you for sure as I haven't done it. Hopefully someone will chime in with the procedure so you can tell which one it is. If not I bet a quick google search will get you the right info.
'09 JK
Lockers and stuff
SlinkyTJ is offline
post #3 of 3 Old 05-29-2007, 12:11 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Two big wires and two small wires bolt to a solenoid, they are easily replaced. Just make sure you disconnect the winch from the battery before starting the job. And before you get too far into it, start out by just tightening all the nuts holding the cabling to the solenoids and checking the battery connections. It may be nothing more than a loose nut holding a cable to one of the solenoids.
Jerry Bransford is online now
another winch question Matt_G General Jeep & Off-Road Equipment 29 01-24-2010 10:49 AM
Question about winch buying winch for front bumper jeep53191 General Jeep & Off-Road Equipment 0 10-07-2009 08:30 PM
winch question wranglerkid95 General Jeep & Off-Road Equipment 3 04-21-2009 03:24 PM
Winch question 4x4Mudmonster General Jeep & Off-Road Equipment 4 05-27-2008 06:07 PM
Question on a winch skip97 General Jeep & Off-Road Equipment 20 03-14-2007 01:22 PM
