Why is it bad to have a body lift and a suspension lift? - JeepForum.com
post #1 of 22 Old 03-09-2009, 07:46 PM Thread Starter
XJKingJeezy
I am looking into buying a lift kit. I am looking for a cheeper solution. And was looking into a body lift kit. Around 2 or 3 inches. But I want more lift in the future. So I was gonna get a suspension lift like 3 inches later when I have the funds. But I recently herd this is a bad idea? Why? And is it safe or safer if it's only a small lift on each kit?
Thanks for any help
XJKingJeezy is offline
post #2 of 22 Old 03-09-2009, 07:50 PM
fedrusion
Your XJ is unibody, no body lift.
1999 Cherokee 2 Door Sport (To be modified) Mine.
5.5" Composite lift, Rough Country Control Arm Drop Brackets, 31X10.5X15 Dayton Timberline AT's On Canyons, 31X10.5 Firestone Destination MT's, P.O.R.C. SYE and front CV Drive Shaft, Homemade Short Ram Intake, Locked 8.25. Comming Soon: Stroker.
2000 Grand Cherokee Laredo (To be left alone) Wife's.
fedrusion is offline
post #3 of 22 Old 03-09-2009, 08:24 PM Thread Starter
XJKingJeezy
Ok that makes sence. Is there anyother way to get more tire clearance without using a full suspension lift?
post #4 of 22 Old 03-09-2009, 08:25 PM
BriansCJ
BriansCJ's Avatar
1994 XJ Cherokee
Sawzaw or shackles and spacers.
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #5 of 22 Old 03-09-2009, 08:28 PM Thread Starter
XJKingJeezy
Alright. When you trim the wells what do you all cut out? And any recomendations on a good website for shakles and that stuff?
post #6 of 22 Old 03-09-2009, 08:29 PM
mylt1
mylt1's Avatar
your better off with a lift kit. rustys 3" kit is nice, its what i have on my XJ. if your competent with hand tools it shouldnt take more than a saturday to install.
mylt1 is offline
post #7 of 22 Old 03-09-2009, 08:30 PM
mylt1
mylt1's Avatar
you can only cut so much because the body is where a unibody gets its strength.
mylt1 is offline
post #8 of 22 Old 03-09-2009, 08:32 PM Thread Starter
XJKingJeezy
Ok cool. What size tires are you running with the rusty 3"
post #9 of 22 Old 03-10-2009, 06:48 PM
fedrusion
You should be able to fit 31x10.5x15 tires easily with a 3" kit from rustys. A 2" budget lift should allow for 30x9.5x15 tires. If you go with a budget lift make sure it uses shackles for the rear and not blocks or an add a leaf. You will be able to use the shackle later on if you lift it more.
post #10 of 22 Old 03-10-2009, 08:54 PM Thread Starter
XJKingJeezy
Awesome thanks. Any info on the 4.5" lift? What tires? Pros and cons?
post #11 of 22 Old 03-11-2009, 08:22 PM
fedrusion
Its a rustys 3" lift, sat 4.5" in the back 3.5" in the front, added a 1" spacer to level it out. Runing 31" Dayton Tiberline AT's every day and run 31" Destination MT's for wheeling. Love it. Pro's: Pretty much fun all around whether I'm Wheeling or just cruising around. Cons: A Little loss in fuel econemy due to larger/heavier tires.
post #12 of 22 Old 03-12-2009, 01:15 PM
1996BlackXJ
1996BlackXJ's Avatar
Make sure you look into fender trimming before you go hack them up. If you cut the rear fenders you will have a big hole that goes straight into your cab. You have to cut and fold the fender.
-Max Black 1996 XJ
4.5" lift of assorted brands, 33x10.5 KM2s on D-Windows, JCR rear bumper, Nates Slimline w/Champion 8k winch, custom half doors, roof rack, and tire carrier, Maine Woods dents and pin striping, and various other cool things.
Maine Jeep Club Member #1 Firefighter Jeep Club Member Black Jeep Society Member #163Survivalist Jeep Club Member #14
1996BlackXJ is offline
post #13 of 22 Old 03-12-2009, 02:34 PM Thread Starter
XJKingJeezy
will the .75 frnt spacers with the 3" lift level it out?
post #14 of 22 Old 03-12-2009, 06:53 PM
fedrusion
I would install the 3" lift before worrying about spacers, measure after lifting to get your actual lift then add spacers if necesary to level it out.
post #15 of 22 Old 03-13-2009, 09:38 AM Thread Starter
XJKingJeezy
Ok. Awesome. Well I just looked at my leafs and I noticed that they have sagged so much that they are now flat. I'm wondering if I should just get new leafs and then throw some spacers up front. This seems like a cheeper way to get a few more inches out of my jeep. Is this a good idea?
Can I clear 32x11.5x15s with only a 2.5 suspension lift (no body lift) on my 2006 TJ? ddonjon General Jeep & Off-Road Equipment 3 04-21-2009 10:49 AM
Whats the diff between Body Lift and Suspension Lift? loudog3114 Tires & Wheels 7 02-01-2005 02:27 PM
body lift or suspension lift 2001tj Tires & Wheels 18 12-05-2001 06:10 AM
suspension lift vs. body lift Howie Tires & Wheels 0 11-27-2001 09:41 AM
Body Lift with Suspension Lift?? RockinTJ Tires & Wheels 0 04-13-2001 12:45 PM
