When to lock ARB's and when not to??? - JeepForum.com
post #1 of 2 Old 03-28-2002, 08:37 AM Thread Starter
dreid33
Guest
Hey all,
I need some 4-wheeling advice. I have always had vehicles that have open diffs. Well, I am proud to say I just got a new 1994 Jeep Wrangler with ARB in the front and rear.
Here is my question. When should I engage them? I have heard you have more of a chance for breaking axles with ARB's and I do not want to risk that.
Someone told me, when going up hill, use only the rear locker. When crawling on rocks, use both. When on a sideways hill, use neither, because they will walk you sideways. What about loose dirt on steep hills or in muddy terrain?
Does this make sense to everyone? Any advice and personal experience would be appreciated!
I am sure the usually goes as in any 4-wheeling. If you start spinning the tires, lay off the gas or you will bust an axle.
Thanks!
dreid33 is offline
post #2 of 2 Old 03-28-2002, 01:54 PM
osburn
osburn's Avatar
I've been running ARBs front and rear a long time. You'll find it's not difficult to decide at all. Generally, off road, I run with the rear engaged damn near all the time and only turn on the front if I have the slightest inclination I will need it. Sometimes, when I come to a really rocky section and I will need to make tight turns I leave the front off and only turn it on if I detect slipping. Just about anytime I'm pointed uphill, both ends are on. Downhill, always try to get the front turned off before you head downhill. Steering is a real bear when the front is engaged downhill. On sidehills it is nice to be able to turn both ends off if you don't need them. Lockers can cause sidestepping in this situation.
The only exception to all of this was on a rescue once when I was on stock axles. Concerned with the added stress of towing a vehicle off a hard trail I ran as much as possible with no lockers engaged. But rather than have wheel spin, I engaged the lockers.
I think you'll find as time goes on, you won't even think about their engagement. It will just become second nature much like shifting your tranny.
Matt Osburn
Score 1032
osburn is offline
Getting ARB's with compressor or OBA treeofliberty General Jeep & Off-Road Equipment 9 03-31-2007 08:31 AM
I know that the ARB's have been around for... Trikstr General Jeep & Off-Road Equipment 6 03-20-2003 02:13 AM
need d44 before arb's? RD General Jeep & Off-Road Equipment 1 12-28-2002 07:44 PM
ARB's and axles RD General Jeep & Off-Road Equipment 1 12-23-2002 08:39 AM
