what possi should i run in the front of a Dana 30 front - JeepForum.com
post #1 of 11 Old 05-21-2020, 10:30 AM Thread Starter
bentleyfab
Got a new jeep started taking stuff apart on the front end and realized my axle had welding spatter on it turns out someone welded the front spider gears not sure what to run up there looking for recommendations
bentleyfab is offline
post #2 of 11 Old 05-21-2020, 10:42 AM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
That would depend on what your goal is and how much you want to spend, but you're not going to be running a 'posi' in a front end. Maybe a locker, if that's the way you want to go.
For a more budget fix, there are thousands upon thousands of D30 front axles in salvage yards. Finding a used carrier and gears would be fairly easy.
Mid-range, there are plenty of sources for new carriers, lockers and gears. Just do an overhaul.
Or high-end, you can spend thousands on a complete built axle.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #3 of 11 Old 05-21-2020, 10:51 AM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Or watch your local craigslist for someone parting out the appropriate year/model/gear ratio Jeep and just get the whole axle and just swap it in.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #4 of 11 Old 05-21-2020, 03:06 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
What kinda Jeep you have probably will influence your traction device choice, whatcha got ?
The only Limited Slip worth the purchase price is a Detroit TrueTrac.
When the people find that they can vote themselves money, that will herald the end of the Republic.
- Benjamin Franklin
CJ7-Tim is offline
post #5 of 11 Old 05-22-2020, 05:34 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Don't forget the Powr Lok as well (I'm a bit of a fan).
The duty of a patriot is to protect his country from it's government
Thomas Payne
jeepdaddy2000 is offline
post #6 of 11 Old 05-23-2020, 02:00 PM
BYuen
BYuen's Avatar
X2. If you want a limited slip, go with the TrueTrac. It is a gear based limited slip so there are no clutches to burn out.
Another option to consider is a "lunch box locker." They are cost effective and re-use your existing carrier (no need to mess with your gears). All you do is swap out the internals. The locker will act like an open diff in 2wd, but lock up when torque is applied in 4wd.
2001 White TJ Sport
2013 Black JKU Rubicon 10A
BYuen is online now
post #7 of 11 Old 05-24-2020, 09:00 AM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
Im not sure, but I wouldnt think you would be able to disassemble a Lincoln locker in order to be able to reuse the carrier.
Build Thread:
Swing Away / Swing Down Tire Carrier:
NashvilleTJ is offline
post #8 of 11 Old 05-26-2020, 08:54 AM
BYuen
BYuen's Avatar
Originally Posted by NashvilleTJ View Post
I’m not sure, but I wouldn’t think you would be able to disassemble a Lincoln locker in order to be able to reuse the carrier.
Not quite sure what you mean, but there are two types of auto lockers. One is like a detroit full carrier replacement, and the other is a drop in locker that fits into the existing carrier and replaces the spider gears. With the detroit, you will have to re-set your gears because it is a complete unit with it's own carrier. With the drop in lockers like an Aussie Locker, Spartan Locker, etc.; you have to remove the carrier and ring gear from the axle to install them, but you won't have to do any gear set work as long as you don't touch anything else and put everything back exactly the way it was. These "lunchbox" type lockers only replace the factory carrier internals.
2001 White TJ Sport
BYuen is online now
post #9 of 11 Old 05-26-2020, 10:16 AM
NashvilleTJ
I miss the snow...
The OP's spider gears are apparently welded together to create what effectively is a spool. The term "Lincoln Locker" is used to describe this approach - the reference being to the Lincoln Welder.
You suggested that the OP could install a lunch box locker, which requires removing and replacing the spider gears, and reusing the carrier. The point of my post was that I'm not sure the OP could remove the spider gears and reuse the carrier to do so since the spider gears (and perhaps also the carrier depending on how sloppy the welds are) are welder together.
Make sense?
Jeff
Build Thread:
post #10 of 11 Old 05-26-2020, 11:23 AM
BYuen
BYuen's Avatar
Make sense?
Jeff
Oh got it! I misunderstood what lincoln locker meant.
Yea I guess it depends how the gears are welded in there if the OP can get them out.
2001 White TJ Sport
BYuen is online now
post #11 of 11 Old 05-26-2020, 08:30 PM
jeepdaddy2000
1971 CJ5
The tru trac will wear out as well. The difference is the powr lok is rebuildable. It will also take a terrific amount of abuse, to include large tires. Don't get me wrong, I like them both, just pointing out there is more than one option.
Thomas Payne
