What Gear Ratio Is Best?? - JeepForum.com
post #1 of 6 Old 03-17-2002, 03:52 PM Thread Starter
omar
Guest
I just bought a jeep and I've recently installed a 4 inch lift and some 33s. My friends tell me that I need gears. What Ratio do I get?? And do I need to put gears in the front axle as well??
omar is offline
post #2 of 6 Old 03-17-2002, 04:34 PM
igofshn
Locked @ both ends
igofshn's Avatar
Meed some info on your Jeep. 2.5/4.0, auto/manual? Yes you will have to change front and rear.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
post #3 of 6 Old 03-17-2002, 04:38 PM
aroberts
Guest
My 02 TJ Sport came with 3.07 gearing. Been changed to 4.10. Much better than before. You have to change front and rear because they have to turn at the same speed.
aroberts is offline
post #4 of 6 Old 03-17-2002, 06:27 PM Thread Starter
omar
Guest
I have a 2.5L 5 Speed.
omar is offline
post #5 of 6 Old 03-17-2002, 06:30 PM
igofshn
Locked @ both ends
igofshn's Avatar
It came with 4.10's. You should change to 4.56's. You would be vey happy with that,
igofshn is offline
post #6 of 6 Old 03-17-2002, 09:48 PM
kegmaster
Guest
yeah, either 4.56s or 4.88s.
kegmaster is offline
Gear Ratio JeepX89 Engines & Drivetrain 3 05-04-2008 09:35 AM
Gear ratio marko686 Engines & Drivetrain 7 04-20-2008 03:19 PM
Which ratio to re-gear valeech Engines & Drivetrain 6 08-24-2006 02:33 PM
gear ratio? jrodum Tires & Wheels 4 08-16-2005 01:21 PM
35c gear ratio mde General Jeep & Off-Road Equipment 6 04-03-2002 04:53 AM
