Warn Zeon Winch Drum Corrosion? - JeepForum.com
 1Likes
  • 1 Post By 97TJGUZZY
post #1 of 10 Old 08-07-2020, 02:58 PM Thread Starter
97TJGUZZY
97TJGUZZY's Avatar
Hey guys, I have had a zeon on my jk for the last 4 years. I use it 4-5 times a year but never really spool it down to the last wrap on the drum. Well, I recently bought a new Zeon for my TJ and while spooling the line on using the hill in the back yard, I decided to respool the JK line also. When I unwound it to the bare drum I found it was corroded with white oxidation all over the drum and first wrap of winch line heat guard.
Has anyone had this problem, I assume most people haven't spooled theirs down to the bare drum very often.
For the record this jeep is garage kept. Here are some pics for reference.
CAC212BE-5DD6-47DE-B68C-4AC752DFC716_1597065252130.jpg   F78F1B1C-D39C-4336-93B4-464391B13356_1597065268520.jpg   74686467-C1EA-4BD1-9F9D-6EC52A955BC3_1597065300313.jpg   34574729-5499-4436-AF0A-6A994590B3E9_1597065316495.jpg
For info on outdoor adventures in South Carolina check out
97TJGUZZY is offline
post #2 of 10 Old 08-09-2020, 11:48 AM
jimsmiths
jimsmiths's Avatar
So, I was spooling the winch line on my TJ and I figured while I had the tree savers hooked up I would respool the JK winch line. When I ...
jimsmiths is offline
post #3 of 10 Old 08-10-2020, 07:13 AM Thread Starter
97TJGUZZY
97TJGUZZY's Avatar
1
post #4 of 10 Old 08-10-2020, 07:17 AM Thread Starter
97TJGUZZY
97TJGUZZY's Avatar
The thing is I never would have known because it looked totally normal the 10-15 times I've used the winch in the last few years because I don't usually spool it down to the bare drum.
Anyone else with a zeon want to unspool their winch to the drum for a little science experiment?
Good time for a little winch line bath.
8262B55C-F857-49C4-A00C-1997743F2800_1597065523893.jpg   4CD90239-337D-40DB-AEA4-CA337258BD1F_1597065534936.jpg
post #5 of 10 Old 08-10-2020, 07:29 AM
222Doc
222Doc's Avatar
Have you contacted Warren? i would guess it was wet for a time? I have a 10s and use it well each season. Have never used all the line but have had it out about 75%.
Ill pull mine and check. But here in AZ rain is rather rare and the heep is a off road jeep 99%. Sits in one of garages until its put on a trailer.
Oxidized perhaps the drum should be coated with a good Polyurethane epoxy?
Jim nothing to add but a grammar check?
222Doc is offline
post #6 of 10 Old 08-10-2020, 08:01 AM Thread Starter
97TJGUZZY
97TJGUZZY's Avatar
I have contacted Warn, They are opening a help ticket, but they said they had never heard of this before.
post #7 of 10 Old 08-10-2020, 08:09 AM
222Doc
222Doc's Avatar
I have a run in under two weeks on the Dusy Ershem and since that is no place to have anything go wrong. I will be checking to see if my spool looks like that. Not that it wont work but still, not good. I wonder if there may a chemical in the ropes shield that is causing that kind of electrolytic corrosion ?
just a hypotheses. Ground issue?
I'll get back on this thread when i pull the line all the way.
222Doc is offline
post #8 of 10 Old 08-10-2020, 08:12 AM Thread Starter
97TJGUZZY
97TJGUZZY's Avatar
from my understanding of Arizona weather, I would hope that yours looks brand new under the line. Yall get rain like 2 times a year right?
post #9 of 10 Old 08-10-2020, 12:24 PM
222Doc
222Doc's Avatar
Yea.... BUT its only 11am and its 110 in shade and should get just under 120. So i just spooled it out all the way and winched up hill to load it. Spool looks like it did when i put it in close to four years. That just reminded me why i NEVER wheel in this heat and go to places like Dusy this time of year.
But if i recall the only two times this line got wet. But both times i am sure that dried well coming to the hellish heat of AZ.
Not sure how hard it might be pull these apart for a new spool. Bet its a pain too. Heck just to remove mine you must pull it with bumper as a unit. Anyway at least i know its all good line still looks good down deep no kinks or binds. My drive way is very steep so its a pull too. I need some lemon aid now. great drink when its hot.
maybe just wrap a bit of Emory cloth and clean it down while its spinning?
222Doc is offline
post #10 of 10 Old 08-10-2020, 01:07 PM Thread Starter
97TJGUZZY
97TJGUZZY's Avatar
Thanks for checking, anyone in the southeast want to check their winch drum for me? I found a few instances on other forums.
222Doc likes this.
