Warn Winch Rebuild - JeepForum.com
post #1 of 6 Old 11-30-2019, 04:26 PM Thread Starter
Letzride
Warn Winch Rebuild
Hi all,
Looking for a little guidance with a warn winch rebuild - specifically the VR8000 winch.
It stopped working on me a few weeks ago up north. When I got it home I opened it up and pulled it apart. The motor was so corroded I didn't even bother to see if a rebuild was possible.
I bought a new motor that I am going to be installing shortly.
I wanted to clean off the gears from the opposite side of the motor and repack them with grease, but I am not sure what the best way is to do this?
What grease is best to use? What is the best way to clean the gears? Is there anything I can do like put silicone around the motor housing to help keep moisture out in the future etc?
1999 TJ 4" Lift - 33's
Letzride is offline
post #2 of 6 Old 11-30-2019, 04:27 PM Thread Starter
Letzride
Also, I was trying to see if I could replace the bearing closest to the motor, but I can't seem to figure out how to get it out of the housing, or find the part number needed to replace it?
Letzride is offline
post #3 of 6 Old 12-02-2019, 12:23 PM
cranbiz
cranbiz's Avatar
Try this.
https://winchserviceparts.com/vr8000.php
06 KJ
12 JK, 2.5" Teraflex lift, Bilstein 5100's, BFG KM3's 37x12.5/R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #4 of 6 Old 12-02-2019, 04:35 PM Thread Starter
Letzride
Originally Posted by cranbiz View Post
I actually just ordered from them. I got fed up trying to get the broken bolts out of the motor housing supports. After spending about 12 hours and having one whole side still jammed up on me, $50 sounded a lot easier lol.
I am still hoping to figure out what the best type of grease is to use when packing the winch gears, and how much to use and how to properly pack them?
Letzride is offline
post #5 of 6 Old 12-19-2019, 12:11 AM Thread Starter
Letzride
Bump - no one has rebuilt a winch?
Letzride is offline
post #6 of 6 Old 12-23-2019, 12:09 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Warn recommends moly grease, call Warn's customer service department for specific recommendations. There are many videos on rebuilding Warn winches on YouTube, just Google them. Avoid heavy greases like wheel bearing grease or it'll be a booger to pull the rope out in free spool.
Jerry Bransford is offline
