Warn rope replacement - JeepForum.com
 1Likes
  • 1 Post By Mud Machine
post #1 of 4 Old 08-22-2019, 07:31 AM Thread Starter
danb303
danb303's Avatar
I need a replacement synthetic rope for a Warn Zeon 8s.
Anyone have any suggestions?
2006 LJR Auto. 35" tires, 538 gears, IRO 4"lift. Tom Woods! JKS TB, Rancho 5000x, Currie Correctlync
danb303 is offline
post #2 of 4 Old 08-29-2019, 12:51 PM
Mud Machine
Mud Machine's Avatar
TRE - Tactical Recovery Equipment
Jerry Bransford likes this.
BDS Springs, MetalCloak Arms, Fox Shocks, Warn Winch, Savvy Ft Bumper, Antirock, GenRight Fenders, GR8 Top, 35" Pittbulls, 5.13's, Revolution Axle Shafts, LS/6.0, 4L80e
'76 CJ-7, 33" Swampers, 6-Point Cage, 4-Speed, Dana 300 Twin Stick
Mud Machine is offline
post #3 of 4 Old 09-02-2019, 10:03 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
X2, contact Ricky there and make sure to go with 3/8" not 5/16". 5/16" is technically strong enough but with synthetic rope you want the extra safety margin of 3/8" in case the rope gets damaged from abrasion.
www.tacticalrecoveryequipment.com
Jerry Bransford is offline
post #4 of 4 Old 09-11-2019, 07:05 AM
222Doc
222Doc's Avatar
might be the same design as my 10s? Not that you have to use the warren's rope. One could braid a lope in the end of any. or go back to old way. But on mine the start of line feeds through the spool and has a small lope at the end of the rope. once that is pushed through the hole a wedge is placed in the loop. then set that by pulling it into the spool. the rope can not come of the spool now. it would wind it up the other way if you used all the line. but they want two arms and a leg for a Warren replacement. matter of fact its more then the china made winch i had once. when i wear this one out i will do my own loop braid for that wedge.
222Doc is offline
