Undercarriage rust - JeepForum.com
post #1 of 8 Old 08-05-2015, 10:12 AM Thread Starter
Tman96
Undercarriage rust
My 03 wj has light surface rust on almost every part of the undercarriage, axles, driveshaft, exhaust, practically every thing under the vehicle. I did some poking and prodding and there is no serious damage, at worst some light flaking, but would wire brushing it off help? I don't have the money to do a full on undercoating. So should I leave it as is, brush it, or brush and rattle can undercoat it?
Tman96 is offline
post #2 of 8 Old 08-05-2015, 11:19 AM
Ross
A few times a year I get under my jeep and cover any exposed metal with spray paint. Yours doesn't seem to be an issue. I would scrape of the loose stuff clean good and hit it with some rustoleum and regularly check to make sure you keep the exposed metal covered.
01TJ33sWarn,ARBs F&R,bellyup,4.0,4.56s,5spd
99 XJ33sWinch,Electric locker up front,4.56s,4.0Auto
Ross is offline
post #3 of 8 Old 08-05-2015, 11:24 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
What you might do depends greatly on where you drive. If the highway department uses salt to melt snow and ice on the roads, you need to monitor and deal with the rust. If you drive anywhere else, it will be fine, just like it is.
“We the people are the rightful masters of both Congress and the Courts,
not to overthrow the Constitution but to overthrow the men who would pervert the Constitution” Abraham Lincoln, 1859.
CJ7-Tim is offline
post #4 of 8 Old 08-05-2015, 04:13 PM Thread Starter
Tman96
Yeah it's definitely not that bad. I'll clean it up and hit with some rustoleum. Should I avoid parts that get hot or can regular spray paint handle the heat?
Tman96 is offline
post #5 of 8 Old 08-05-2015, 04:48 PM
CJ7-Tim
CJ7-Tim's Avatar
Wet or dry, paint burns.
CJ7-Tim is offline
post #6 of 8 Old 08-11-2015, 08:42 PM
VARIABLE9
You can try a product like FluidFilm as well.
VARIABLE9 is offline
post #7 of 8 Old 08-12-2015, 07:00 AM
biffgnar
biffgnar's Avatar
Mavcoat is great stuff
biffgnar is offline
post #8 of 8 Old 08-13-2015, 11:09 AM Thread Starter
Tman96
So I coated it I naval jelly wiped/hosed that off. Brushed and washed again. Then I did a coat of rustoleum rusty metal primer, then a coat of rustoleum protective enamel.
Tman96 is offline
