Track Bar or Lack there of for CJ7 - JeepForum.com
post #1 of 7 Old 06-13-2021, 11:03 AM Thread Starter
wheelbearing
Hello
I am new here,
I have a Customers !986 CJ7 that is in need of a track bar.
It is all over the road, As in UNSAFE to drive.
Can Anyone help with suggestions as to where I can get one or have one made ?
Thanks
Wheelbearing...
wheelbearing is offline
post #2 of 7 Old 06-13-2021, 11:29 AM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
CJs didn't come with track bars and shouldn't need one, being a leaf spring set-up. Coil spring/control arm suspensions are what need track bars. I'm not even aware of an aftermarket track bar made for CJs.
If it's all over the road, there's a reason for it that shouldn't require a track bar to fix. I'd start with inspecting spring and other suspension bushings, possibly a loose steering gear issue...
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #3 of 7 Old 06-13-2021, 01:37 PM
222Doc
222Doc's Avatar
its allover the road.......would be looking at the shackles, front end condition and camber, steering box ect.
222Doc is offline
post #4 of 7 Old 06-13-2021, 03:21 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Being lifted with high arch springs makes wandering a lot worse. I had to use a track bar on my YJ with 6" SUA lift or it was dangerous. After going SOA with much flatter springs, the bar was not needed.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" Patagonia M/Ts, AX15, NP231+4:1+SYE+2LO, York OBA.
Web Admin for
JeeperDon is online now
post #5 of 7 Old 06-13-2021, 04:03 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Stock?
Steering wheel centered?
Alignment checked?
I suggest you post multiple pictures of the Jeeps suspension. Having a look at what we are dealing with may shed light on the issue.
Paperwork will ruin any military force.
Chesty Puller
jeepdaddy2000 is offline
post #6 of 7 Old 06-13-2021, 08:52 PM Thread Starter
wheelbearing
Hello
The customer bought the Jeep this way, he's stuck with it driving it as it is
I have been there done that checking and verifying the shackles, springs, steering gear box..
Spring bushings were replaced with the tougher polyurethane bushings front and rear of the Springs.
Steering box is NOT loose..
When turning the steering wheel the front end moves back and forth.
The front spring shackles seem to sway, or that's where the movement seems to come from.
33in tires don't help, 4in lift doesn't help.
Many thousands of people have done this set up, Somebody must have come up with a fix.
post #7 of 7 Old 06-14-2021, 02:25 PM
Fourtrail
1974 CJ6
What is the length of the shackle? is there a welded bar between the two halves if they are longer than stock? drop pitman arm? draglink angle? tire pressure? there are still many things that need to be considered before throwing a track bar on the front. There are lots of fixes, pictures of the front end setup will help us make other suggestions at to what can be done to minimize the wandering.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is online now
