Trac-Lock LSD: Opinions? - JeepForum.com
post #1 of 6 Old 02-11-2002, 06:04 PM Thread Starter
evilpsych
evilpsych's Avatar
hey guys, payday's comin up soon and I've seen a sale on track-lock LSD's on some of the various dealer ads. Whats the general consensus of this diff? Good/Bad wears out quickly? etc.. i know i have to use the clutch pack lube with it. My jeep is pretty much stock and prolly wont see more than 31" tires. just want a little bit more than open diffs for the type of stuff i do.
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #2 of 6 Old 02-11-2002, 06:06 PM Thread Starter
evilpsych
evilpsych's Avatar
oh.. this LSD is for the D35 ( i know i know, sucky axle) does anyone know of one for the front D30 axle?
A
post #3 of 6 Old 02-11-2002, 08:49 PM
bob91yj
Guest
Save your money, you can do almost as much with the parking brake as you can with the Trac-Loc, especially at dealer pricing.
bob91yj is offline
post #4 of 6 Old 02-11-2002, 11:24 PM Thread Starter
evilpsych
evilpsych's Avatar
hahahhaa... ok ok yeah.. i did a little more reading.. still wish there was an affordable quality LSD out there
A
post #5 of 6 Old 02-26-2002, 07:41 PM
Liberty-4-All
Guest
There is...Detroit TrueTrac ( no clutches to wear out...about $335.00...or the Auburn...Trac-Lok is good if you got it with your vehicle but I would not buy one to install...the others are much better
Liberty-4-All is offline
post #6 of 6 Old 03-17-2002, 05:06 PM
aroberts
Guest
I have a Tru Trac. Haven't used it a lot, but it seems to work ok. I have been told that with one tire in the air I will wish I had put in an ARB.
Still, in mud and bumps the lsd should be ok.
aroberts is offline
Weld-On Bead Lock Opinions mountaineerjp Tires & Wheels 0 01-08-2010 08:01 AM
Trac Lock vs spool safarimike Engines & Drivetrain 16 04-21-2009 05:57 PM
8.8 Trac-Lock mod TJmudpuppy Engines & Drivetrain 0 12-16-2008 09:04 PM
Command Trac to Select Trac swap md10 Engines & Drivetrain 0 09-12-2008 11:29 AM
Selec Trac Vs. Quadra Trac Ii Jeep04Special General Jeep & Off-Road Equipment 5 06-09-2004 09:05 AM
