Tow Rope with Hooks - Page 2 - JeepForum.com
post #16 of 28 Old 10-18-2006, 04:08 PM
Chris_Ryan
Chris_Ryan's Avatar
When ever possible DO NOT pull from the front (as in don't have your jeep in reverse) you can cause damage to your trany and diff gears.
- Who says there is nowhere to run in New England and New York
Originally Posted by vBulletin Message
Sorry, you can not add yourself to your own ignore list.
Chris_Ryan is offline
post #17 of 28 Old 10-18-2006, 04:39 PM
mylt1
mylt1's Avatar
where did you get that little misfit of information? i have pulled many times from the front with no damage. so quote your source please.
mylt1 is offline
post #18 of 28 Old 10-18-2006, 04:45 PM
Chris_Ryan
Chris_Ryan's Avatar
I have heard it many times on here, and also a buddy who used to work for a 4x4 shop down by the ocala state forest in Fl.
This is how my buddy explained to me (at least the diff)... It had to do with the way the differential gears are shaped, they have a curved edge and a straight edge when you are moving forward the flat edge of the gear is in contact but when you are in reverse, the curved edge of the gear is in contact. A simple pull of your differential cover will confirm the shape of the gear.
To me that makes sense, and I don't want to blow a d35 testing it out...
post #19 of 28 Old 10-18-2006, 04:46 PM
19OlllllllO41
19OlllllllO41's Avatar
Ive also heard this many times over the years. Thats why I never pull in reverse!
The Present:
'05 TJ Rubicon (Electric Lime Green)
'04 WJ
'46 CJ2A
The Past:
'83 CJ7, '92 YJ, '00 XJ, '99 TJ, '05 TJ Rubicon (Impact Orange)
19OlllllllO41 is offline
post #20 of 28 Old 10-18-2006, 05:07 PM
Jeepfreak81
Jeepfreak81's Avatar
There is a difference in strength of the front axle... a high pinion front axle is weaker pulling in reverse as compared to a low pinion model. However I have pulled in reverse in my YJ and never had issue. I like to pull from the rear of my jeep in case the strap breaks it will hit the rear and less chance of coming through the windshield.
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies
1946 CJ2A, 225 V6, T98 D18, Warn OD, D30/D44. Dual winches mild lift & 34's
1966 M416 1/4 ton Military Trailer Expo Trailer
Full Page Club member #004
Green Jeep Club Member #005
Jeepfreak81 is offline
post #21 of 28 Old 10-18-2006, 08:39 PM
Car RamRod
if you see a r&p you'll understand why you dont want to pull in reverse, there is much less contact area between the teeth. Then count in any change in pinion angle and it adds a lot more stress to the housing=flex=more clearnaces=baddd. A manual transmission shouldnt really make a difference as the gears mesh, but I would still try to pull foward whenever possible.
1986 Comanche, 4x4, 2.8l v6
1989 Mustang LX Coupe, h/c/i, bolt ons, 5lug
have to break in engine and trans, then hitting E-town and a dyno
Car RamRod is offline
post #22 of 28 Old 10-18-2006, 09:46 PM
sparkeep
If you must pull in reverse... have a spotter off to the side in a safe location give the puller instructions. To protect the driver of the pull vehicle from death (in the case of ropes with hooks being the only available strap) raise the hood fully as a shield. This can be done for winching as well if you are unsure of the safety of the pull.
2005 Impact Orange Rubicon
6 speed standard 4.0L I6 engine
Mechanical Engineer behind the wheel
Toronto, ON, Canada
sparkeep is offline
post #23 of 28 Old 10-19-2006, 10:09 AM
Car RamRod
good idea.
post #24 of 28 Old 10-19-2006, 10:20 AM
gunthagunth
gunthagunth's Avatar
i cant open my hood anymore when winching. id rather have it come thru the windshield .
97 ZJ 5.9L 242/4.5" RE Coils/1.75" Spacers/Clayton arms/Addco's/RE brake lines/35x12.5 bfg muds/Currie steering/K&N/Claytons Front Drop tracbar/Dropped pitman/Bilstein 5125's/JKS BPE/JKS loop conversion/JKS Sliders/ZJilla rear bumper/Clayton front winch bumper/durango steering box/warn 9000i/Hambek Customs carbon fiber cowl hood #2of16/Hp30-8.8 4.56/ARB f+r
gunthagunth is offline
post #25 of 28 Old 10-19-2006, 05:24 PM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Just don't do what I did. No horror story here, but the other guys sure did scare some sense into me!
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline
post #26 of 28 Old 10-19-2006, 07:52 PM
AZG23
I keep a recovery strap for recovery...and a tow strap with hooks for the pull home if I break something...
Brad B.
"If you cant understand that, your face needs to be set ablaze with kerosene and promptly put out with a wet brick."
AZG23 is offline
post #27 of 28 Old 10-20-2006, 01:24 AM
jocww
jocww's Avatar
if u you pull in reverse though the gears are lower or numerically higher so it should therefore be better. unless your rig is a recovery only the strength should not be a issue at all. I pull in reverse all the time partly because of the winch up front but even in our tahoe
red 86 xj 3.5 superflex with packs, deutush shocks hella 500 fog lights cb radio 31 dayton mud terrains on 15x8 ion wheels custom front bumper with winch and rear tow point
for you myspacers girlscuddlebug69
Bay Area wheelers click this link
TvisXJ Did he just pull a Woo Wong? Chevelle Yea... he just pulled a Woo Wong
Originally Posted by XJIceQueen98
Real women don't drive hummers... they give them
jocww is offline
post #28 of 28 Old 10-20-2006, 02:17 PM
Car RamRod
we're on different pages.
I was talking about the strength that the components could handle, not what the truck would be putting out.
Wire Rope vs Synthetic Rope duckman1 General Jeep & Off-Road Equipment 5 09-16-2009 01:14 PM
Where do you mount your recovery hardware? Tow hooks? Clevis hooks? jrodum General Jeep & Off-Road Equipment 9 11-12-2007 06:45 PM
Where do YOu mount your tow hooks? clevis hooks? pics jrodum General Jeep & Off-Road Equipment 2 10-01-2007 08:37 AM
Rope question StormnThunder General Jeep & Off-Road Equipment 5 11-04-2006 06:49 PM
Wire Rope or not... 99TJ General Jeep & Off-Road Equipment 1 02-21-2002 06:40 AM
