Tow dolly broke jeep - JeepForum.com
post #1 of 15 Old 08-19-2019, 08:58 AM Thread Starter
jadejeep
2014 JK Wrangler
I posted this in another forum but thought I might get more eyes here...hope that’s allowed!
I just finished using a tow dolly to drag my 2014 rubicon to the beach and back. Back wheels on ground, front off. OOPS! Duh... now it won’t get into gear. I was told I need a new transmission. Is that true? Help! I’m a idiot....
jadejeep is offline
post #2 of 15 Old 08-19-2019, 10:07 AM
jtec
jtec's Avatar
2014 JK Wrangler
Well not recommended* - Its been done SO
lets just work thru this step by step.
what Gear selection is transfer case in?
Engine will start Idle smooth?
Is the CEL (Check Engine Light) on?
Selecting a gear - no movement, will reverse lights come on in R?
Trans fluid was checked? level - color, particles?
page 616 owners manual...
* Page 562 owners manual - a little late
there should be a test .
jtec is offline
post #3 of 15 Old 08-20-2019, 09:26 AM Thread Starter
jadejeep
2014 JK Wrangler
Hi! Thanks for replying! I’ll work through these questions and post as soon as I can!
jadejeep is offline
post #4 of 15 Old 08-20-2019, 12:32 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
There is a specific way to do this and not following the instructions as outlined in the owner's manual WILL trash your transmission.
What were your transfer case and transmission set at while you did this towing?
The t-case should have been in neutral and the transmission should have been in park.
The transmission pump that lubricates the tranny is at the front of the tranny, and is spun by the engine/torque converter. If you left the transmission in neutral, it was being spun from behind as you towed it and the tranny pump was not moving, thus not lubricating the tranny.
This is probably the most common transmission killer by those who don't read the owner's manual and tow with the tranny in neutral.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #5 of 15 Old 08-20-2019, 02:02 PM Thread Starter
jadejeep
2014 JK Wrangler
Ugh yeah tranny neutral , tcase 2wd. Think the tcase is broken too?
jadejeep is offline
post #6 of 15 Old 08-20-2019, 03:11 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Tcase should be fine, it's pump system is much simpler and constantly lubes if the main shaft is spinning.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #7 of 15 Old 08-20-2019, 04:09 PM
mukluk
mukluk's Avatar
This is contrary to the response you gave in your other thread on the same subject: https://www.jeepforum.com/forum/f19/.../#post40713659
2000 TJ SE
2005 LJ Rubicon
mukluk is online now
post #8 of 15 Old 08-20-2019, 04:43 PM
K0LCB
K0LCB's Avatar
I have always thought Jeeps couldnít be towed on dollies. I never tried. I tow mine 4 down, my JK is 6th Jeep Iíve owned
L. C. AKA LEONARD
Itís a Jeep thing
K0LCB is offline
post #9 of 15 Old 08-20-2019, 05:07 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
It's all depends on the t-case.
Ones with full-time AWD like Quadratrac model t-cases can't be dollied, as the front and rear are always (at least partially) engaged with each other, even when the tcase is in neutral.
Models like the JK have a t-case that fully disengages front and rear drive lines from each other, so they can handle it for short distances. The owner's manual does say not to do it at all.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #10 of 15 Old 08-21-2019, 09:05 AM Thread Starter
jadejeep
2014 JK Wrangler
This is contrary to the response you gave in your other thread on the same subject: https://www.jeepforum.com/forum/f19/t.../#post40713659
Thanks corrected that!!
jadejeep is offline
post #11 of 15 Old 08-21-2019, 09:13 AM Thread Starter
jadejeep
2014 JK Wrangler
It’s a 2014 rubicon, so it’s awd right? This really sucks
jadejeep is offline
post #12 of 15 Old 08-21-2019, 12:58 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
No, it's 4wd. It has the ability to be in either 2wd or 4wd.
AWD is always in some form of 4wd and doesn't have a 2wd option.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #13 of 15 Old 08-22-2019, 08:58 AM Thread Starter
jadejeep
2014 JK Wrangler
Ok cool at least maybe the tcase is ok then....
jadejeep is offline
post #14 of 15 Old 08-23-2019, 01:46 AM
samthorn
Never was in these situation
Interesting discussion
Thanks!
My
. Garage owner. Based in London.
samthorn is offline
post #15 of 15 Old 08-24-2019, 09:14 AM
V8GCZJ
I disconnected the drive shaft on my ZJ to get it home with a tow dolly(hung it from the exhaust). If in question it's easier to remove/install 4 bolts rather then trans/t case.
V8GCZJ is offline
