Tires for a smoother ride - JeepForum.com
post #1 of 7 Old 08-25-2021, 01:10 PM Thread Starter
Nangell313
I have a 2 1/2 inch lift kid on my 4 door 2016 Jeep Wrangler with 17 inch wheels. Right now I have 35” tires on and I’m looking to tone it done to something that will make it a smoother and less noisy ride. Any suggestions are helpful. I understand that removing the lift kit could help with that drastically but I don’t have the means for that at the moment , I’m in New England and the height secures my on street parking spot in the winters. Haha. Thanks again!
Nangell313 is offline
post #2 of 7 Old 08-25-2021, 01:31 PM
222Doc
222Doc's Avatar
well that lift has nothing to do with. All Mts are noisy as they age more so. Ats are better but not like a car tire.
smooth ride is about shocks and what psi you run those 35s at. a 35x12.5x17 example on a JK will be like 29psi+- not 37 like stock. If this is the case that may be part of your issue. Shocks this about smooooth not sound......
222Doc is online now
post #3 of 7 Old 08-26-2021, 10:32 AM
Pillswoj
Pillswoj's Avatar
2014 JK Wrangler
Its all relative. What tires do you currently have? If they are a load range E Mud Terrain, then the fix is to find a load range C all terrain.
BFG AT KO2 in 315/70r17 is load range C and has good winter performance you would want in NE. If however you are already on a load C all terrain then the recommendation is tougher.
Jeff
2014 2 dr Rubicon
Pillswoj is offline
post #4 of 7 Old 09-28-2021, 08:21 AM
aglemped
What wheels and tires does your Jeep have on?
aglemped is offline
post #5 of 7 Old 09-28-2021, 01:25 PM
cranbiz
cranbiz's Avatar
While a harder sidewall tire (Load range D or E) will cause it to ride rougher, your springs and shocks will also. A good progressive spring for your lift and different shocks will make a world of difference too.
What manufacturers lift do you have and what shocks are on it?
02 WJ Laredo, heavily optioned but stock
12 JK, 3.5" Teraflex/Franken lift, Bilstein 5100's, BFG KM3's 37x12.5/R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #6 of 7 Old 09-28-2021, 02:53 PM
Htnbuks
I have heard OME and anything “hydro” ride well. The “nitro” are more for off-road.
Sent from my iPhone using Tapatalk
Htnbuks is offline
post #7 of 7 Old 10-09-2021, 04:32 PM
dchemphill1
dchemphill1's Avatar
2020 LJ Wrangler
Live in Nebraska and love the Goodrich AT KO2 load C. Rides nice but was great in snow last winter and was great on Colorado Jeep trails. BTW 33's is what I have been running on my 2 dr Rubicon
dchemphill1 is offline
