Spare Tire Question... - JeepForum.com
post #1 of 11 Old 08-15-2020, 05:19 PM Thread Starter
DJC
DJC's Avatar
1979 CJ5
When I bought my ‘79 CJ5, the previous owner had 31” tires and a 31” spare.
I replaced the four tires with 33x12.50R15 tires, but never upgraded the spare.
Seems to me, maybe one time, I put the 31” spare on and it functioned, but obviously not ideal.
It really should be same height, so was planning on buying a 33x10.50R15 and a 15” rim to fit it (existing rim is like 6” wide, maybe 7”).
A full 12.50” width spare seems excessive as the spare tire is mounted on the rear carrier and sticks out, plus the 12.50’s are heavier, etc.
Is a 33x10.50 R15 tire as the Spare a good way to proceed?
Thanks
DJC is offline
post #2 of 11 Old 08-16-2020, 11:32 AM
jserna
1987 YJ Wrangler
Yes. I did the same thing. Also it is a huge weight savings hanging off the back of the jeep. Save your back.
jserna is offline
post #3 of 11 Old 08-16-2020, 02:15 PM Thread Starter
DJC
DJC's Avatar
1979 CJ5
Thank You.
I thought about trying to find an even skinnier, 33-inch tall light truck tire that might still fit the narrow rim. Maybe a military tire. Something that is the correct height, but narrower and lightweight.
Some people just bring a tire repair kit and air pump/compressed air bottle, but what about a bent or broken rim or torn sidewall?
DJC is offline
post #4 of 11 Old 08-16-2020, 03:16 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Wise Jeepers bring a spare tire, a repair kit, and an inner tube. You can stitch together a cut up tire with bailing wire, pad the repair with rags, and air up the inner tube.
“We the people are the rightful masters of both Congress and the Courts,
not to overthrow the Constitution but to overthrow the men who would pervert the Constitution” Abraham Lincoln, 1859.
CJ7-Tim is offline
post #5 of 11 Old 08-16-2020, 03:19 PM Thread Starter
DJC
DJC's Avatar
1979 CJ5
Sounds like a plan!!!
DJC is offline
post #6 of 11 Old 08-18-2020, 04:22 PM
92 Green YJ
92 Green YJ's Avatar
Originally Posted by DJC View Post
Thank You.
I haven’t carried a spare tire in 5 years now. When I bought my 40s I only bought 4. I carry a good plug and patch kit and I have on board air. I have never once damaged a tire badly enough that I couldn’t fix it with a couple of plugs or less. I’ve never once used a patch. I have also never bent or broken a wheel.
92 Jeep Wrangler Unlimited +
Tons, 40s, tons of mods
92 Green YJ is offline
post #7 of 11 Old 08-18-2020, 05:19 PM Thread Starter
DJC
DJC's Avatar
1979 CJ5
Good to know.
Thanks
DJC is offline
post #8 of 11 Old 08-18-2020, 05:31 PM
CJ7-Tim
CJ7-Tim's Avatar
Not to be a Richard about it, but if you don't have spare and need one, your junk is sitting off to the side of the trail while the rest of us move on. Unprepared is not a good way to make new friends out in the wilderness. Any organized event or well run 4x4 club requires a spare tire.
I have cut several sidewalls, and even cut two on consecutive trail days. I bought a replacement and a spare when we got back to town.
CJ7-Tim is offline
post #9 of 11 Old 08-18-2020, 06:25 PM
92 Green YJ
Originally Posted by CJ7-Tim View Post
Not to be a Richard about it, but if you don't have spare and need one, your junk is sitting off to the side of the trail while the rest of us move on. Unprepared is not a good way to make friends out in the wilderness. Any organized event or well run 4x4 club requires a spare tire.
Sounds like you need a better tire with a tougher sidewall. I ran ProComp Xterrains for years. Only ever punctured a sidewall once and 4 plugs fixed it right up. Now I’m running bias ply Trepadors.
post #10 of 11 Old 08-20-2020, 02:46 PM
cranbiz
cranbiz's Avatar
And no matter how tough your sidewalls are, crap happens.
I have KM3's which have a pretty tough sidewall. I lost one on an unexpected tree root that would have taken out any tire. No amount of plugs would have fixed my 3" gash.
If I didn't have a spare, the entire trail would have been blocked for quite some time.
02 WJ Laredo, heavily optioned but stock
12 JK, 3.5" Teraflex/Franken lift, Bilstein 5100's, BFG KM3's 37x12.5/R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #11 of 11 Old 08-20-2020, 03:07 PM
4Low2G0
4Low2G0's Avatar
I always carry a spare and have a plug kit, never needed ether, but I have them if I do.
also have a small 12V air supply
Spare needs to be same circumference if you have a limited slip diff or locker.
Open diff a smaller tire is not ideal but will work.
Whats over that next ridge?
4Low2G0 is offline
