Seeking correct Optima battery-2008 JGC - JeepForum.com
post #1 of 8 Old 09-15-2020, 01:30 PM Thread Starter
peglegmeg77
Hi, seeking an Optima battery to fit my 2008 Jeep GC; V8, 4.7L. Specs below. Any ideas? Thanks.
Group Size
H7
Minimum Cold Cranking Amps
750
Group Size
H8
850
peglegmeg77 is offline
post #2 of 8 Old 09-15-2020, 02:03 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Don't waste your money. Optimas are not nearly what they used to be quality-wise since production was moved to Mexico.
You're better off with an Advance Auto/Die Hard AGM in the proper group size.
See my Gates Energy/Optima history thread:
https://www.jeepforum.com/forum/f20/...story-4394795/
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #3 of 8 Old 09-16-2020, 08:54 AM
cranbiz
cranbiz's Avatar
I'm happy with my now 4 year old Advance Platinum AGM battery. It's in my JK but it's been absolutely reliable.
Now if you really want a premium battery, go with an Odyssey.
06 KJ
12 JK, 2.5" Teraflex lift, Bilstein 5100's, BFG KM3's 37x12.5/R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #4 of 8 Old 09-16-2020, 09:57 AM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
X2. The Odyssey Extreme AGM is one of the best (I run them in my rig, my tow vehicle, and my cars. But they definitely fall into the "Get what you pay for" category as they are pricey. I switched from running Optima's after Johnson Controls moved production to Mexico - which was when quality went down the tubes. I made the mistake of buying two Optima's after that time, and both failed in under two years.
Build Thread:
Swing Away / Swing Down Tire Carrier:
NashvilleTJ is offline
post #5 of 8 Old 09-18-2020, 01:55 PM Thread Starter
peglegmeg77
Thanks
Thank you for your responses, incites, and personal stories. Appreciated. I have also spoken to some friends, and am considering alternatives to Optima.
post #6 of 8 Old 09-18-2020, 09:48 PM
rjbruzan
Or the NorthStar at Batteries Plus.Pricey but an excellent choice.
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #7 of 8 Old 09-23-2020, 04:02 PM
havit
havit's Avatar
2003 JK Wrangler
Optima batteries aren't as good as they used to be i am presently using the Odyssey Extreme AGM and I suggest you should too
havit is offline
post #8 of 8 Old 09-26-2020, 11:02 AM
V8GCZJ
Any reason it needs to be sealed? Nothing wrong with lead /acid.
V8GCZJ is offline
