scuba tank - JeepForum.com
post #1 of 11 Old 05-13-2010, 07:22 PM Thread Starter
khill8469
scuba tank
i have everything comming for my arb air locker. i have the big arb compressor comming. tonight someone offered me a scuba tank to use with it. What i need to know is what i need to hook it up and would it be worth it for me.
khill8469 is offline
post #2 of 11 Old 05-14-2010, 03:46 PM Thread Starter
khill8469
bumb anyone know?
post #3 of 11 Old 05-14-2010, 03:58 PM
NJMike
How about a little more info? Is it a steel or aluminum tank? Is the valve tapping NPT or does it utilize a non tapered thread and an O-ring?
Guns kill people like spoons made Rosie O'Donnell fat.
NJMike is offline
post #4 of 11 Old 05-14-2010, 05:24 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
You need a good quality air pressure regulator to reduce the scuba tank's potential 2000-3000 psi down to the ARB's 90-100 psi. Personally, I would not use a scuba tank for that purpose.
Jerry Bransford is online now
post #5 of 11 Old 05-14-2010, 06:03 PM
TiredOldMan
TiredOldMan's Avatar
You can have that SCUBA tank converted to nitrogen or CO2. Last one I had done cost me 35.00 if I remember correctly. That was a hydrostatic test and a new valve. However if you just watch CL you can sometimes pick up ready to go CO2 cylinders for that price or less.
Looking for MB Shock wheel 15x8 5on4.5 3.75bs
" The problem with socialism is that eventually you run out of other peoples money"
Margaret Thatcher
TiredOldMan is offline
post #6 of 11 Old 05-14-2010, 06:32 PM
mylt1
mylt1's Avatar
i dont think he is going to be using the tank at the standard pressure. the way i read it is he is getting a compressor for the ARB so he could use the scuba tank as a tank for the compressor.
mylt1 is offline
post #7 of 11 Old 05-14-2010, 07:16 PM Thread Starter
khill8469
your right im using a high volume arb compressor im thinking about using it as just a tank. would it be better just to buy a real tank or use the scuba tank. i figured if i decide to mount it under the jeep the scuba tank will hold up better outside. Im not sure if i will use it on the outside of the keep just keeping my options open.
post #8 of 11 Old 05-14-2010, 07:34 PM
TiredOldMan
The problem with using that tank for a compressor is that you only have one port. What are you going to do for a water drain?
I suppose you could drill and tap whatever other ports you might want. Although a regular 2gl. tank is fairly cheap and has mounting brackets and plenty of ports.
Margaret Thatcher
post #9 of 11 Old 05-14-2010, 09:53 PM
escapeartist
I seem to recall if you take the valve out of the tank it is a standard 7/8 NPT. Maybe you could drill a hole in the side and have a bung welded/heliarced on so you can have an inlet and an outlet. Dunno if this is what you are after.
Those who say it cannot be done should be quiet and not interrupt those whom are doing it.
escapeartist is offline
post #10 of 11 Old 05-14-2010, 11:06 PM
Jerry Bransford
Administrator
Oh ok yeah as TiredOldMan said, a scuba tank is not suitable due to its single port, plus they are HEAVY. Just get a standard 2.5 gallon air tank, they have all the necessary bungs (ports) to make the whole job a lot easier.
post #11 of 11 Old 05-15-2010, 08:09 AM Thread Starter
khill8469
ok thankyou. i guess ill buy a tank. another question i was thinking. so if i put a 2.5 gallon tank in. could i set up a removable 5 gallon tank. it would be good when i go out but take up to much room for an every day thing in my jeep.
scuba tank oba? neuterbigwilly General Jeep & Off-Road Equipment 10 04-13-2010 09:46 PM
Need a way to secure a scuba tank for OBA DBLJ General Jeep & Off-Road Equipment 8 06-23-2009 09:25 PM
Converting Scuba Tank to CO2 StrokedWJ General Jeep & Off-Road Equipment 11 02-15-2008 09:56 AM
Scuba Tank MBaltrusitis Audio, CB & Ham Radios, GPS, & Electrical 3 07-20-2007 08:18 AM
Converting Scuba Tank hrjaw General Jeep & Off-Road Equipment 14 02-15-2007 12:31 PM
