Rubicon transfer case vs a Dana 30? - JeepForum.com
post #1 of 6 Old 03-04-2016, 01:46 PM Thread Starter
billytoad631
So I just picked up a Rubi case with the 4:1. I run a Dana 30/44 with 4:56s. Chromo's front and rear. 30 spline front and rear. ARB lockers front and rear.
My question is do you guys think the axles can handle the low end torque that the 4:1 is going to produce? I'm kind of worried about my 30 exploding the r&p or maybe even the 44 r&p
I've looked around online but I can't seem to find anybody running a d30 with the 241or
Opinions?
Sent from my iPhone using Tapatalk
instagram @billytoad631
my tj https://www.jeepforum.com/forum/f22/billys-financial-mistake-3446386/
billytoad631 is offline
post #2 of 6 Old 03-04-2016, 03:04 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
A Rubi t-case is not the only way to get 4:1 or better, and they all work fine. Tire size effects axle longevity way more than the motor side. Yes it will be fine.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #3 of 6 Old 03-04-2016, 03:19 PM
biffgnar
biffgnar's Avatar
Will be perfectly fine
biffgnar is offline
post #4 of 6 Old 03-07-2016, 07:21 PM
BlueRubiconrich
you will be fine
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #5 of 6 Old 03-07-2016, 07:24 PM
BlueRubiconrich
If you had a Dana 35 rear, well then you will be in trouble.
post #6 of 6 Old 03-08-2016, 06:08 PM
Subotai
Subotai's Avatar
I have a the Rock Track 241 Rubicon Transfercase 4:1 in my 91 YJ with Dana 44 rear and the 30 front with one piece Chromo's and the Warn locking hubs, lockers front and rear with 4:11 gears, 33" tires and its SOLID!
The weak link is the Dana 30 hear but only if you get over the 35' tire size, some would say the 35". Without the Chromo's axels forget it though.
Subotai is offline
