Rear window help! - JeepForum.com
post #1 of 2 Old 09-28-2019, 04:24 PM Thread Starter
PAG123
Rear window help!
Recently bought a 2010 Wrangler sport with soft top. The windows were pretty scratched up so I ordered a new window kit (Mopar 82209934). The side windows fit but the back window does not. The zipper teeth on the soft top rear panel are larger than the zipper teeth on the new window. There is also two different zippers on the soft top panel with a small open square at the top center that gets velcroed over.. while the new window has a continuous zip. When I contacted the vendor they said I must have an after market top...which I’m surprised about i assumed it was original. Anyone have any idea where I can find a back window that would fit this description? Thanks!
PAG123 is offline
post #2 of 2 Old 09-28-2019, 05:55 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
You need to figure out who made the top. There's quite a few manufacturers and they are all pretty similar, but very few are interchangeable.
They also all have some sort of identifying tag or stamping somewhere on them. Check all the window corners for stamped markings and all the stitched seams for tags sewn in.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
