JeepForum.com (https://www.jeepforum.com/forum/)
-   General Jeep & Off-Road Equipment (https://www.jeepforum.com/forum/f27/)
-   -   RE-build startup procedure (https://www.jeepforum.com/forum/f27/re-build-startup-procedure-4429869/)
WFOMO 04-08-2021 04:06 PM
My '85 CJ-7 (4.2) has a factory rebuilt engine in it with only about 40 K miles, but the previous owner blew a head gasket, which I fixed and had the heads/valves redone while I was at it.
Never had oil pressure worth anything even though compression was very good. So I tore it down and the bearings were the issue (not horrible, but bad enough). Replaced all the bearings and put on a high volume oil pump. Everything was put back together with assembly lube, so is there any problem with pulling the plugs and crank it over using the starter to put oil back in everywhere before actually firing it up?
mukluk 04-08-2021 11:21 PM
Shouldn't be any problems with that, just don't overheat the starter.
jeepdaddy2000 04-09-2021 05:51 AM
A better option is to pull the distributor and spin the oil pump that way. Run the pump till you get oil on the top end and oil pressure at the gauge.
WFOMO 04-10-2021 08:31 AM
Just tried that and it worked perfectly. Thanks!
The time now is 07:54 PM.
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
