Please clarify this question regarding lunchbox lockers in the front - JeepForum.com
post #1 of 22 Old 02-06-2015, 06:41 PM Thread Starter
Utah_Jay
Utah_Jay's Avatar
2018 JK Wrangler
I have read several threads on several forums regarding putting an Aussie or the like in the front of the Dana 30. Everything I have read said it doesn't engage in 2WD and only locks when in 4WD or torque applied to the front end.
The guy at 4 wheel parts said it is locked full time even in 2WD.
Which is correct?
2007 JKU Sport
Utah_Jay is offline
post #2 of 22 Old 02-06-2015, 08:56 PM
TexasTJ
No Longer DD
TexasTJ's Avatar
In 2wd the only thing it may do is make a clicking sound. I used to have an Aussie and it clicked all the way around the turn, but never had a problem with it. I bought it on craigslist, used it for a bit, now my friend is using it.
2wd off
4wd on
Sold 11/18/19 :(
May TJ of the Month 2015
TexasTJ is offline
post #3 of 22 Old 02-07-2015, 12:39 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
With out the ability to unlock the front hubs the locker will continuously engage and disengage around corners. If you're running a 231 or other t case that allows a 2 wheel drive mode, this will be a bit of a non issue, as it may make some noise, but should be invisible otherwise.
jeepdaddy2000 is offline
post #4 of 22 Old 02-07-2015, 07:09 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
On dry or wet pavement, a front lunchbox locker is OK. No strange behaviors, and no unusual noises. It does not engage in 2wd because there is no torque input to the axle.
I always recommend locking the rear axle first. A selectable locker, or a Limited Slip is the best choice for the front axle.
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
post #5 of 22 Old 02-07-2015, 09:03 AM
1tonmut
1tonmut's Avatar
1983 CJ7
Yes of course, it's always locked.
The teeth of the side gears are spring loaded against the teeth of the axle gears so the only time it's not locked is when the wheels are going different speeds which causes the gears to ramp out and skip teeth (making noise) until the gears re-engage.
It's similar in function to a detroit locker, better off with a limited slip or a selectable air electric or mechanical locker in front.
Lunchbox lockers are much better suited for the rear axle.
I agree with what JeeperDon said.
"people here will say it's fine,but that just means they are willing to live with the quirks."
1tonmut is offline
post #6 of 22 Old 02-07-2015, 09:43 AM
Indy
Indy's Avatar
If you have manual hubs you'll never know it's there. A lunchbox is always locked until its forced to unlock.
I'm the only gay eskimo.
Indy is offline
post #7 of 22 Old 02-07-2015, 10:41 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
There's some baseless conjecture and lack of personal experience with a front-mounted lunchbox locker in a TJ above. First, a front-mounted lunchbox locker is a non-issue on the street when you're in 2wd. Most click through turns but that's it. My previous TJ's Powertrax No-Slip lunchbox locker mounted in my front axle didn't even click, you literally couldn't tell it was there in 2wd on the street.
While it is true lunchbox lockers are always locked, they don't lock up hard enough to cause any steering issues until you shift into 4x4. They unlock so easily when in 2wd that, again, a front-mounted lunchbox locker is an absolute non-issue in 2wd on the street. At the most they only click through turns when you're in 2wd on the street.
And never listen to what a 4WP salesman says about such things... most are totally clueless and most only know about lifting big trucks with lots of chrome-plated parts. Few are into Jeeps or know much about them.
If you don't mind clicking through turns, the Aussie would be a great choice, followed by the Powertrax Lockrite. If you don't want any noticeable clicking through turns, spend about $100 more for the Powertrax No-Slip lunchbox locker.
Jerry Bransford is offline
post #8 of 22 Old 02-07-2015, 05:09 PM
tookie
The front gearset and driveshaft will always spin, even in 2WD... which will be an issue if
your front shaft is not well balanced, or has worn components. Even if they are
in great shape, gas mileage will be worse.
Before I got a trailer, I used to flat tow, and after installing the lockright, Jeep would
no longer follow the truck thru a turn, wheels wanted to stay straight... never figured
that one out, but I don't flat tow anymore, plus I got locking hubs...
tookie is offline
post #9 of 22 Old 02-07-2015, 11:04 PM
shotgunsmith
I have a lockright in the front for the past 90k. Flat tow without any problems. In 2X it's non-issue. Only use 4x4 in snow when it's needed. Meaning I cant move. Been anticipating it's replacement but it just keeps working. I did an inspection thisweek and it all looks great.
"If a law is stupid, you have to break it."
HST
shotgunsmith is offline
post #10 of 22 Old 02-08-2015, 07:10 AM
Airstreamer67
I agree with Jerry 100%. My Aussie doesn't affect anything in 2WD except a little clicking when turning, and I don't even notice that except perhaps in very tight and slow turns.
But when you need the pulling power in the mud in 4WD, boy does it ever earn its keep! Wow!
Airstreamer67 is offline
post #11 of 22 Old 02-08-2015, 08:19 PM
armyRN
armyRN's Avatar
Location: Longview, WA (one hour north of Portland, OR)
x3; just saying. I've had an Aussie in the front of my TJ since 2008.
You can teach manners, but you can't teach class.
Trailer build:
armyRN is offline
post #12 of 22 Old 02-09-2015, 10:43 AM Thread Starter
Utah_Jay
Utah_Jay's Avatar
2018 JK Wrangler
Thanks for the replies, going to go with an Aussie and try it out on the EJS this year.
2007 JKU Sport
Utah_Jay is offline
post #13 of 22 Old 02-12-2015, 07:34 PM
amp713
amp713's Avatar
You wont regret it at all.. I love the Aussie and its pulled me over some stuff here in utah that others couldnt touch with rear lockers
I like my YJ how I like my whiskey, on the rocks with just a touch of color!
amp713 is offline
post #14 of 22 Old 02-12-2015, 07:50 PM
armyRN
armyRN's Avatar
In my little flat fender I used to have a powerlock (clutch pack limited slip) in the rear and it really didn't do much. I pulled it and put a lock-right in the rear and it made a significant difference. But when I added the lock-right to the front, then it pretty much went anywhere. As long as I had a tire on something that tire had power going to it. I'm not going to say it was unstoppable (31" tires, pinto four cylinder engine), but it was amazing.
Trailer build:
armyRN is offline
post #15 of 22 Old 02-15-2015, 09:03 AM
stich
1949 CJ3A
I have Lock Rights in front and rear of my 49 and mated up with the Buick 231 and T98 4sp, it really does go anywhere....(that I want to go anyways)
stich is offline
