OFF ROADING TIPS? - JeepForum.com
post #1 of 15 Old 03-03-2002, 05:36 PM Thread Starter
AKULARED
Guest
OFF ROADING TIPS?
I've just realized my dream of owning a Jeep, is there a site that can give me any info on off roading driving techniques?
AKULARED is offline
post #2 of 15 Old 03-03-2002, 06:25 PM
evilpsych
evilpsych's Avatar
well.. ther are several.. but here's the main keys ingredients to a successful off-road excursion
1. have recovery equipment (strap, come-along, winch(optional), gloves, shovel, etc..)
2. be aware of where your differentials are in relation to large trail rocks you are going over.
3. if you do not have lockers or quick disconnnects, be aware that lifting more than one tire off the ground at a time will more than likely get you stuck, (even if you have a positrac/limited slip).
4. going slow (in 4 low) over rocky terrain is better than Ironman Stewarting them..
there are many more, but it's pretty much common sense stuff that you will learn along the way. the gloves and the shovel come in handy for when you will ineveitably high-side your vehicle for digging it out and rolling large rocks into its path so you can get moving.
A hi-Lift jack is worth its weight in gold.
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #3 of 15 Old 03-03-2002, 06:57 PM Thread Starter
AKULARED
Guest
Thanx for the info!!
one thing I wanted to know,
while i was off roading in the mud and rocks, i noticed that while riding through areally rocky patch i was playing with the clutch alot ( in and out constantly) in order to go slow enough not to shread my tires yet fast enough not to stall
how are the clutches in a stock TYs? can they handle that? or will I burn it?
is there a better method?
hey thanks again for your insight...
AKULARED is offline
post #4 of 15 Old 03-03-2002, 08:45 PM
treedodger
Have you stalled your jeep in 1st gear, 4-low? it can be quite torquey at low speeds, even idle. Try it if you haven't already. If your jeep still isn't slow enough, maybe a regear or a slower transmission or transfercase should be investigated. Although a little clutch work is alright, feathering is bad for any clutch's life expectancey. If you can smell the clutch burning, you're doing something wrong.
treedodger is offline
post #5 of 15 Old 03-03-2002, 09:17 PM Thread Starter
AKULARED
Guest
THANKS TREE
Yeah i gotta get the feel for it i guess- i was in 4 wheel high- i havent stalled yet i guess its the fear of stalling the had me feathering the clutch-
when should i use low as opposed to high?
i can feel the obvious diff but the manual said something about not using low for offroading use?
AKULARED is offline
post #6 of 15 Old 03-04-2002, 07:58 AM
ooze
whats really interesting is stalling while on a steep grade pointing up.
(gotta get my park brake fixed or grow another foot)
one safety tip is keep your thumbs out of the inside of the steering wheel.
ooze is offline
post #7 of 15 Old 03-04-2002, 04:25 PM
RodeoRob
RodeoRob's Avatar
Check this article out... its not Jeep specific, but applys to anyone with a manual tranny.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
post #8 of 15 Old 03-04-2002, 07:21 PM
kegmaster
Guest
get a BIG front bumper and hit anything that gets in your way or you cant turn around...Rob? Agree?
kegmaster is offline
post #9 of 15 Old 03-04-2002, 09:13 PM
ooze
hmm.. i've done that to get me to the fuel station after running out of gas. my wife thought i was nuts. but it kept her from having to push me, hehe.
ooze is offline
post #10 of 15 Old 03-04-2002, 09:54 PM
RodeoRob
RodeoRob's Avatar
I definitely agree Nothing helps cover up bad driving better than 1/4" plate steel bolted to the front of your rig I've even used mine to move the occasional Honda out of my parking spot or remove wandering animals from our state roads
-Rob
-Rob
Robert Gorrell
RodeoRob is offline
post #11 of 15 Old 03-05-2002, 11:29 AM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
Let remind our new friend that, if you can't make it up a steep hill, TURNING AROUND is NOT usually the right thing to do. Back it down slowly, or you might be roll'n, roll'n, roll'n . . . and break off those nice sideview mirrors.
Also, anytime 4-high is too fast at idle, use 4-low. Even on pavement, 1st gear idle would take a long time to mess up your x-case.
'82 Scrambler - NV4500/4.5" lift/33" Toyo MTs/4.0/twin stick, OX Locker and my windshield washers work! Full 1/2 cab Cage
2014 Harley FLHP Police Road King
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
CJeep is offline
post #12 of 15 Old 03-05-2002, 01:57 PM Thread Starter
AKULARED
Guest
Thanx Brudduhas
Thats all really great info that i'll take to heart, i know that experience is the best teacher, but im stoked to know that i have some brothers in mud out there if i get stuck..
thanks again!!
AKULARED is offline
post #13 of 15 Old 03-05-2002, 03:59 PM
treedodger
Brothers in mud? Is that all? Don't forget brothers in rocks, roots, snow, asphalt, sand, gravel, and wherever else your jeep might try to take you. Then there are the jeepchicks too-sisters in mud??? I dunno
post #14 of 15 Old 03-12-2002, 09:11 AM
BaileyTJ
here is a link
"If you don't plan, you plan for failure"
BaileyTJ is offline
post #15 of 15 Old 03-12-2002, 11:48 AM Thread Starter
AKULARED
Guest
THANKS FOR THE LINK
IT HAS SOME GREAT INFORMATION
THANKS AGAIN BRUDDAHS
AKULARED is offline
New to off roading, BruinsFan311 General Jeep & Off-Road Equipment 6 08-04-2007 04:34 PM
off roading in VA? stimulatechamin General Jeep & Off-Road Equipment 10 08-25-2006 05:06 PM
New to Off Roading 4frntmorrison General Jeep & Off-Road Equipment 3 08-23-2005 11:35 PM
Off roading gotfish4689 General Jeep & Off-Road Equipment 2 03-09-2005 08:25 PM
Which is best for off roading? RedBeard General Jeep & Off-Road Equipment 12 07-21-2002 09:57 PM
