Noob - JeepForum.com
 3Likes
  • 1 Post By NashvilleTJ
  • 1 Post By rgunn1
  • 1 Post By BlueFl.Wrangler
post #1 of 12 Old 03-18-2020, 02:37 PM Thread Starter
rgunn1
rgunn1's Avatar
Noob
Just saying hi. New to the forum but I've been playing with Jeeps for a while now. I have a TJ and a CJ7 in the works now. I actually found this place looking for advice on my 7. It's pristine and just about all original (Ithink) but it's been parked for a while and I'm trying to get it running. I'll post up details and pics when I have the post count.
rgunn1 is offline
post #2 of 12 Old 03-19-2020, 08:17 AM Thread Starter
rgunn1
rgunn1's Avatar
Got the CJ running yesterday. $7.99 fuel filter did the trick. I put it on the highway for the first time since I bought it. Shopping for new tires today.
rgunn1 is offline
post #3 of 12 Old 03-24-2020, 09:02 AM Thread Starter
rgunn1
rgunn1's Avatar
New tires on Friday. I had to rewire the passenger side tail light but got everything working over the weekend and managed to pass inspection yesterday, so we're all street legal! Also installed new front flares yesterday and should complete the rears after work tonight. I'll get pics up as soon as I'm able, but I'd really like some guidance on what upgrades I can make to this Jeep without hurting the "value." IE, can I add power steering and/or power brakes, or will that take away from it because they aren't original? I think I'm going to replace the springs and shocks but no lift, just replace the old factory stuff, but I don't even know if that's necessary. I may just need to replace the rubber.
TIA
'82 CJ7 stock
'01 TJ
rgunn1 is offline
post #4 of 12 Old 03-24-2020, 09:54 AM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
TIA
Street legal goes a long way. Good work. The CJ guys will know better than I, but I don't think adding power brakes and power steering will hurt your value unless you are going for a numbers matching restoration - which is likely not worth it with a CJ. Real value wise - in terms of selling it down the road - will improve with the modern conveniences. But since I'm a TJ guy, take that with a grain or two of salt.
Looking forward to seeing pictures when you can. Doesn't look like you need many more posts to be able to do so.
Jeff
rgunn1 likes this.
Build Thread:
Swing Away / Swing Down Tire Carrier:
NashvilleTJ is offline
post #5 of 12 Old 03-24-2020, 02:49 PM Thread Starter
rgunn1
rgunn1's Avatar
Hey, I finally hit 10 posts! Here's a quick shot of the CJ. I'm off to do a little work on it. More to follow.
'82 CJ7 stock
'01 TJ
rgunn1 is offline
post #6 of 12 Old 03-24-2020, 02:52 PM Thread Starter
rgunn1
rgunn1's Avatar
And my TJ from my signature pic. Hopefully wrapping up the project soon... slightly modified....
NashvilleTJ likes this.
'82 CJ7 stock
'01 TJ
rgunn1 is offline
post #7 of 12 Old 03-25-2020, 02:45 PM Thread Starter
rgunn1
rgunn1's Avatar
Finished the flares on the CJ yesterday, first oil change today (I probably should have done that first, right?). Working on a power steering upgrade as well in hopes of eventually doing hydroboost brakes. I need to go through the suspension and fix all of the loose rubber bits. My TJ, well I handed that off to a shop a while back when I didn't have time to wrench every day. I just got an update and was promised pics soon. Frame, axles, suspension, bumpers etc have all been powdercoated (I honestly would have preferred paint) and the Jeep should be going back together. I'm ready to get it on the trail!
'82 CJ7 stock
'01 TJ
rgunn1 is offline
post #8 of 12 Old 03-27-2020, 08:31 PM
BlueFl.Wrangler
Supporting Member
BlueFl.Wrangler's Avatar
Looks like you have a fantastic place to work on it
rgunn1 likes this.
Diplomacy is the art of telling people to go to hell in such a way that they ask for directions
Winston Churchill
BlueFl.Wrangler is offline
post #9 of 12 Old 03-30-2020, 09:20 AM Thread Starter
rgunn1
rgunn1's Avatar
The TJ is at a local shop, Ratchet Garage (https://ratchetgaragellc.com/). I'm working on the CJ in my carport because my old Dodge is in my workshop at home undergoing an axle swap (yes, I have too many projects). Pics to follow....
'82 CJ7 stock
'01 TJ
rgunn1 is offline
post #10 of 12 Old 03-30-2020, 09:40 AM Thread Starter
rgunn1
rgunn1's Avatar
Latest pictures of the TJ going back together after coming back from powdercoat:
'82 CJ7 stock
'01 TJ
rgunn1 is offline
post #11 of 12 Old 03-30-2020, 10:17 AM Thread Starter
rgunn1
rgunn1's Avatar
Axles about to go in...
'82 CJ7 stock
'01 TJ
rgunn1 is offline
post #12 of 12 Old 03-30-2020, 11:21 AM
NashvilleTJ
I miss the snow...
Nice. Looks like they are doing quality work.
Build Thread:
