Mystery threaded plug at top of radiator - JeepForum.com
 1Likes
  • 1 Post By salimoneus
post #1 of 15 Old 09-20-2021, 10:53 AM Thread Starter
salimoneus
Found a coolant leak the other day, turns out that the head of a plastic threaded plug broke off. No idea what that port behind the main cap is even for, maybe some vent tube? Of course the radiator is out of warranty and nobody I talked to knows anything about this part, apparently it's just not available separately. The threads measure 13/16" across.
Anyone end up fixing or replacing one of these before? I'd have to think there's some similar part out there that I could use as a replacement. Gluing it back together just doesn't seem like a good option being right in the middle of the threads. A 3D printer would probably come in handy right about now.
242368961_10220314890198776_2046234369558341366_n.jpg   242497221_10220314892678838_5054825518334326678_n.jpg   242497212_10220314892318829_1803209480633017942_n.jpg
-Rusty's 2" BB
-Durango4x4 bumpers
-Stealth "cubbyhole" subwoofer
salimoneus is offline
post #2 of 15 Old 09-20-2021, 11:20 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
What kinda car ?
If that is a Jeep, cheap Chinese replacement radiators often have a similar plug. It is not meant to have a use, or to be removed. If you are lucky, you might be able to clean and dry the plug and threads and get some JB Weld epoxy to hold it in place. I would replace the radiator, because if your JB Weld repairs fail, you will likely be far from home and need a tow truck.
“We the people are the rightful masters of both Congress and the Courts,
not to overthrow the Constitution but to overthrow the men who would pervert the Constitution” Abraham Lincoln, 1859.
CJ7-Tim is offline
post #3 of 15 Old 09-20-2021, 12:26 PM Thread Starter
salimoneus
Originally Posted by CJ7-Tim View Post
What kinda car ?
Hi, it's a '99 WJ.
I am finding it really hard to replace the entire radiator just for some 50 cent pipe plug. I'd rather somehow fill in that whole cavity with glue or something similar. It's a completely useless port so I won't miss it at all.
-Rusty's 2" BB
-Durango4x4 bumpers
post #4 of 15 Old 09-20-2021, 04:00 PM
CJ7-Tim
CJ7-Tim's Avatar
When the cheap Chinese radiator in my other XJ Cherokee split open, the engine overheated and seized up just as I got to a safe spot on the side of the road. The tow truck cost $189, and the used engine was $600.
A fresh radiator is cheap insurance compared to that ??
CJ7-Tim is offline
post #5 of 15 Old 09-20-2021, 04:11 PM
Fourtrail
1974 CJ6
Looks like a socket head M20-1.5 o-ring plug. Worth a try before ordering a new radiator or jb welding the hole closed
https://www.amazon.com/Moroso-22738-.../dp/B009RL2KGK
o-ringed, so not just a simple pipe plug for 50 cents
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #6 of 15 Old 09-20-2021, 06:19 PM
222Doc
222Doc's Avatar
Well unless its a bush fix( JB, even a pipe plug might go in) it would be best to replace the rad.
Where are OEM made today????????????????????? Mexico? Not like the rad they came with is being made by the same people today.......
New jeeps rads dont last well. I would about bet a top end China one would be better then these from mexico today. But you need to spend money to get higher quality.
Like our two trucks. both have the stock rads still today one is 25 year and the other is 18 years. Even have plastic. But i would bet anything the same one new today wont be as good. Unless you go top shelf and NOT OEM.
China makes parts for these new 3.6s that make jeeps OEM look like junk. Main one is that CHINA made all alloy oil cooler assembly. Jeeps one has failed after design changes to no end. Plastic. China one is all alloy. Yes it cost more, but not much and dealers charge more for the OEM then that cHina one.
If not saying buy China, unless 1 no choice, 2 they do it better. I worry about the latter.
222Doc is offline
post #7 of 15 Old 09-20-2021, 06:23 PM Thread Starter
salimoneus
Hey that looks pretty close, didn't think to use a metric measurement, makes sense though with it likely being a Chinese unit. Thanks will give that a closer look!
-Rusty's 2" BB
-Durango4x4 bumpers
post #8 of 15 Old 09-26-2021, 02:37 AM
Chardagha
Chardagha's Avatar
I’m thinking that a standard pipe plug in brass would be your solution. Take the threaded portion to any Lowes, Home Depot, Tractor Supply, or any auto parts or plumbing house to match up a replacement. Simple fix; no need to R&R the radiator.
Chardagha is offline
post #9 of 15 Old 09-26-2021, 05:35 AM
jay-h
Probably could work. Since the plug is not meant to be removed you can jigger the threads a bit. Use pipe dope on it to help prevent leaks.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #10 of 15 Old 10-04-2021, 02:33 PM Thread Starter
salimoneus
Well the M20-1.5 ended up being just a smidge too small. The Dorman part was only $3 though, so was definitely worth a shot.
-Rusty's 2" BB
-Durango4x4 bumpers
post #11 of 15 Old 10-04-2021, 03:01 PM Thread Starter
salimoneus
The thread pitch on the M20-1.5 is definitely on the mark, so I'll try an M22-1.5 hopefully that should do the trick...
https://www.amazon.com/Dorman-Autogr...dp/B07QQTTF63/
-Rusty's 2" BB
-Durango4x4 bumpers
post #12 of 15 Old 10-04-2021, 03:15 PM
Fourtrail
1974 CJ6
make sure that you transfer the o-ring to the new plug it you want it to seal correctly.
post #13 of 15 Old 10-04-2021, 08:02 PM Thread Starter
salimoneus
Yea I'm going to go with a brand new o-ring, I figure if the plastic plug cracked due to heat/fatigue, the o-ring could probably use replacing as well.
-Rusty's 2" BB
-Durango4x4 bumpers
post #14 of 15 Old 10-07-2021, 08:13 PM Thread Starter
salimoneus
Well the M22x1.5 did the trick, fits perfectly. I ended up snagging this one off ebay because I recently ditched Amazon Prime as it's been going downhill for a while:
https://www.ebay.com/itm/201785920247
The ebay one also seems like a closer match, with the same hex head and space for the o-ring.
Thanks again for the tips all, spent about $15 as opposed to ~$150 for a new radiator.
245001856_10220383775400863_7395514023708758287_n.jpg   244969400_10220383775720871_2108506625609991477_n.jpg
Fourtrail likes this.
-Rusty's 2" BB
-Durango4x4 bumpers
post #15 of 15 Old 10-08-2021, 01:30 PM
Fourtrail
1974 CJ6
