Mini Harbor Freight (type) Trailer Ultimate Build-Up Thread - Page 223 - JeepForum.com
 93Likes
post #3331 of 3345 Old 04-25-2019, 03:33 PM
06LJNC
Need some help on axle length upgrade..
I’m going to run 15x7 wheels with 225/75 tires, freebies from a buddy.
Trailer frame is 40.5” wide.
The loadrite axle I see with the right diameter is 56.5” wide at the hubs
Too wide or not wide enough???
Thanks for the help
Good question. And that will be a nice tire size for your little trailer.
This post and the one that follows (link below) it will guide you to figure out how wide an axle you need.
https://www.jeepforum.com/forum/f27/m...l#post14977300
One you get the measurement off the tire and rim you plan on using, you can figure out your axle width.
Question back to you: These rims you're getting... are they steel rims or alloy rims? Sometimes with the alloy rims, the center hole isn't large enough for the axle hub to pass through. Usually steel rims are ok (hole is larger). Either way, measure the rim's center hole, and compare it to the diameter of the trailer axle hub.
And before you put the flooring down, it would be a good time to swap out the overly-stiff factory slipper springs for some more flexible longer springs with a shackle at the end. It isn't expensive, and you'll be glad you did. It can also give you a little added height.
(from the table of contents first page):
Suspension swap (longer springs with shackles): Page 19, 23, 24, 25, 26, 27, 28, 74, 152 (parts list)
Thanks for the insights, I’ll do some measuring over the weekend. Luckily they are steel, off of a late 90’s Cherokee
Floor is in, onto the sides
Front and a side done. Really liking the look of the T&G.
The axle came in a couple days early!
5AADBC86-809E-4215-B920-686C29108F5A_1556228003804.jpg   9C98A25C-D457-468E-AB3C-BFDF6E1872D6_1556228017754.jpg
06LJNC is offline
post #3332 of 3345 Old 04-25-2019, 09:35 PM Thread Starter
armyRN
armyRN's Avatar
Location: Longview, WA (one hour north of Portland, OR)
Nice! Looks like it is coming along nicely. Keep the pictures coming.
You can teach manners, but you can't teach class.
Trailer build:
armyRN is offline
post #3333 of 3345 Old 04-26-2019, 04:17 PM
06LJNC
[QUOTE=06LJNC;40599525]
Thanks for the help
The axle came in a couple days early![/QUOT
Axle installed and rubber on! Diggin’ it
06LJNC is offline
post #3334 of 3345 Old 04-26-2019, 05:44 PM Thread Starter
armyRN
armyRN's Avatar
Nice! Tell us more about the axle:
Hubface-to-hubface distance, weight rating, where you got it, etc.
Looks like a square-tube axle. Did you have to drill holes in the axle for the spring's center pin?
Trailer build:
armyRN is offline
post #3335 of 3345 Old 04-26-2019, 06:32 PM
06LJNC
Sure thing! Sourced the axle from Eastern Marine as a complete set up.
56.5” hub to hub at 1800lb capacity. Went a little wider in case I choose a different wheel and tire set up, about 2” between the tire and frame.
Hardest part was drilling the hole in the axle to match the spring perch!
Tightened it all up and ready to roll!
Next up is the tailgate and deciding on a top or not....
06LJNC is offline
post #3336 of 3345 Old 04-29-2019, 10:02 AM
06LJNC
56.5 hub to hub at 1800lb capacity. Went a little wider in case I choose a different wheel and tire set up, about 2 between the tire and frame.
Finished up the sides and tailgate, coming along!
06LJNC is offline
post #3337 of 3345 Old 05-01-2019, 06:30 PM
06LJNC
Knocked out the latches for the tailgate and the top as well. She’s ready to roll, heading to the title agency tomorrow. It’s plate time...
C718C231-6E09-4899-B352-0B156EC00BB1_1556756933768.jpg   ADD77663-1567-4D3A-9C18-47859E3E0EBC_1556756964933.jpg   C0548908-2BD3-41FF-96AA-A9283AF4F791_1556756990761.jpg
06LJNC is offline
post #3338 of 3345 Old 05-06-2019, 08:36 AM
NMBruce
Looks good.
2013 JKUR sold
2006 GX470
I knew I shoulda taken that left turn at Albuquerque! - Bugs Bunny
NMBruce is offline
post #3339 of 3345 Old 05-11-2019, 10:27 PM Thread Starter
armyRN
armyRN's Avatar
My trailer has gotten heavier over the years - I either keep bolting things to it, or adding stuff inside the tub. Years ago I replaced the factory overly-stiff slipper springs with longer springs with an eye at each end (so a shackle at the back end). I used these 2-leaf springs (rated at 575lbs each):
https://www.stengelbros.net/US-1001-...ng_p_1688.html
I've been very happy with them, and with the added shock absorbers (all written up previously) it had plenty of flex. And good flex helps keep your trailer's contents from getting beat-up, and keeps stuff from breaking on your trailer.
However, come August (16 Aug - 2 Sep) a group of us are going to go on an 18 day/5000 mile trip from Bellingham WA up to Tukyokatuk (northern Canada) running the Dempster Highway up and back (and do a little kayaking in the Arctic Ocean), and then back to Bellingham (PM me if you're interested in joining us). My trailer will be fully loaded (to include fuel, water, food, and everything else). So I decided to try out these 3-leaf springs (rated at 850lbs each):
https://www.stengelbros.net/US-1005-...ng_p_1915.html
I swapped them out today; easy swap (lengths were the same from eye to eye - 26"). And I still have flex when I push down on the fender. I also gained a 1/2" in height measured from the center-line of the tire to the top of the fender (we'll see if it settles a bit over time). Hopefully they won't be too stiff.
If space permitted on my trailer frame, I'd have gone with these 28" springs (rated at 740lbs each):
https://www.stengelbros.net/US-1030-...ng_p_2568.html
Top picture: old 2-leaf spring and new 3-leaf spring.
Bottom picture: the two old 2-leaf springs.
Anybody want the old springs? They'd be perfect on a trailer like the one posted above on a HF 4' trailer frame. I'll give them away. Mounting hardware (spring brackets, shackles, spring bolts, etc.) are not expensive (and this swap has been written up previously in this thread - it is a bolt-on affair).
deeve likes this.
Trailer build:
armyRN is offline
post #3340 of 3345 Old 05-13-2019, 08:44 AM
06LJNC
http://www.stengelbros.net/US-1001-T...ng_p_1688.html
http://www.stengelbros.net/US-1005-T...ng_p_1915.html
http://www.stengelbros.net/US-1030-T...ng_p_2568.html
I’ll take a look at the build thread you previously posted. Definitely needing something “softer” on my little rig
How much do you think shipping would cost to NC? Kind of an awkward shape to ship!
06LJNC is offline
post #3341 of 3345 Old 05-13-2019, 01:22 PM Thread Starter
armyRN
armyRN's Avatar
Check out page one, first post under the table of contents. There are quite a few posts related to swapping out the springs (with pictures and parts lists).
These would work perfect on your little trailer.
The new ones they shipped me cost $20-something to ship. Give me a zip code and I can find out.
Trailer build:
armyRN is offline
post #3342 of 3345 Old 05-13-2019, 02:15 PM
06LJNC
27713 Durham, NC. Not too far from Ft Bragg
06LJNC is offline
post #3343 of 3345 Old 05-13-2019, 03:40 PM Thread Starter
armyRN
armyRN's Avatar
Airborne!
Trailer build:
armyRN is offline
post #3344 of 3345 Old 05-15-2019, 04:48 PM Thread Starter
armyRN
armyRN's Avatar
Speaking of swapping out springs, here's a link from a previous post that lists the parts needed to do the suspension swap (with pictures!). It is a bolt-on affair with just a little bit of drilling involved. And it isn't that expensive. It really made a difference with my little trailer both on and off-road.
https://www.jeepforum.com/forum/f27/...l#post32123674
And I just checked the links in that post - they still work.
And there is a table of contents on the first page/first post that might help people find other things that have been done over the years (my this thread had gotten long!). Sometimes I'll tell a PAGE number (in which case you'll have to go to that page and scroll down to the applicable post - there are 15 posts per page - this is page 223, post #3344), and sometimes it'll mention a POST (then again - 15 posts-per-page; you'll just have to advance pages till you find it).
Trailer build:
armyRN is offline
post #3345 of 3345 Old Yesterday, 11:55 AM Thread Starter
armyRN
armyRN's Avatar
PM sent.
Trailer build:
armyRN is offline
Harbor Freight Trailer fishinjeeper General Jeep & Off-Road Equipment 14 07-21-2014 11:02 AM
Little Harbor Freight Trailer armyRN General Jeep & Off-Road Equipment 15 04-20-2011 09:03 PM
Harbor Freight Mini-mill otherwise know as Sieg X2?? MA88XJDude Fabrication Shop 13 03-29-2011 06:50 PM
Harbor Freight Trailer with AT's? Anti-bling General Jeep & Off-Road Equipment 8 12-03-2007 06:37 AM
harbor freight trailer willtjx General Jeep & Off-Road Equipment 3 05-04-2005 06:20 AM
