Lifted? Can't tell.. - JeepForum.com
post #1 of 9 Old 05-23-2021, 03:37 PM Thread Starter
brizbayne
1997 XJ Cherokee
Bought a '97 XJ a few years ago and I want to get the front end and suspension all shored up (starting to wobble a bit). Tie rod, sway bar, track bar, stabilizer...they all look pretty stock, but since it's starting to sag, I want to replace shocks and leaf springs eventually as well. Problem is, I can't really tell if it has been lifted by the previous owner. It looks like it sits a little higher than stock (before it started to sag anyways) but I don't want any mismatched parts in the suspension or front end. It's got some old beat up Rancho RS5239 shocks on front and rear but the leaf springs look stock as far as I can tell. Just googling those Ranchos I believe they're for 2" lifts and I also think it may have a ~2" lift spacer on the front springs (see pic)... I'm just not familiar with aftermarket suspension stuff, so any help would be great. As I said, I just don't want to get any mismatched parts. I loved the way it sat when I first bought it, so if it does have a small lift, I'd like to keep it that way. Thanks in advance!
brizbayne is offline
post #2 of 9 Old 05-23-2021, 04:01 PM
rjbruzan
That looks like a 2” spacer
Ron
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #3 of 9 Old 05-24-2021, 05:19 PM Thread Starter
brizbayne
1997 XJ Cherokee
Thanks, Ron! I suspected so, just wasn't certain.
post #4 of 9 Old 06-13-2021, 02:43 AM
JeepJeffW
JeepJeffW's Avatar
Kind of older post but - did you notice any spacers on the body mounts?
"The government cannot give to anybody anything that the government does not first take from somebody else. You cannot multiply wealth by dividing it."
~~~~ Dr. Adrian Rogers, 1984
JeepJeffW is offline
post #5 of 9 Old 06-13-2021, 09:39 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
That would be a really cool modification for a unibody Jeep.
“We the people are the rightful masters of both Congress and the Courts,
not to overthrow the Constitution but to overthrow the men who would pervert the Constitution” Abraham Lincoln, 1859.
CJ7-Tim is offline
post #6 of 9 Old 06-13-2021, 10:25 AM
222Doc
222Doc's Avatar
I was thinking the same must be a PITA to separate the unibody from the uni frame members.......
222Doc is offline
post #7 of 9 Old 06-14-2021, 04:26 AM
JeepJeffW
JeepJeffW's Avatar
Some of us just aren't so called EXPERTS when it comes to all things Jeep. We tend to concentrate on our personal vehicles and, every once in a while, try to contribute to the forum with "possible" relative insights. My constant learning curve was just proven with your enlightening me of this thing called a unibody. Now I have something else to learn about. But don't worry because I will still keep chiming in even if it turns out to be useless information.
post #8 of 9 Old 06-15-2021, 05:20 PM Thread Starter
brizbayne
1997 XJ Cherokee
lol no uni-body mods, but I did a little more looking and found that it has what I believe are 2" leaf spring shackles in the back. I want to replace the saggy leaf springs and I'm thinking of just getting a set of crown hd's. shouldn't be an issue with the post factory shackles, should it?
post #9 of 9 Old 06-16-2021, 11:14 AM
CJ7-Tim
CJ7-Tim's Avatar
Crown HD should stand up to extended shackles. There are some companies that make 2" lift leaf springs, or you might consider an add-a-leaf or building your custom leaf spring pack.
CJ7-Tim is offline
