I dont know what size tire will work with a 3.5" lift - JeepForum.com
post #1 of 7 Old 03-10-2010, 10:45 AM Thread Starter
DeepBlueJeep
I have a 93 jeep wrangler yj, everything on it is stock. i want to get a 3.5" lift and i dont know what size tires will work well on it. i think i want to get 32" or 31" bighorns. will they look small with the lift? if i get bigger tires will i need to get bigger rims? i want to take it 4x4in and such, mostly mudding. what do you all think?
DeepBlueJeep is offline
post #2 of 7 Old 03-11-2010, 04:40 AM
LST022752
If you get the 32x11.5's it will look fine. It might look a little small with 31x10.5's on it though. You should be able to run either of those sizes on your stock wheels. If it were me i'd get the 32's.
Low Output 4-cylinder Club member #177
R.I.P -1995 YJ-
LST022752 is offline
post #3 of 7 Old 03-11-2010, 05:03 AM
daggo66
2009 JK Wrangler
That sounds like the tail wagging the dog. Decide what size tire you want and then get the amount of lift necessary to run that size tire.
Tom
daggo66 is offline
post #4 of 7 Old 03-11-2010, 08:34 AM Thread Starter
DeepBlueJeep
so if i got 32" i could stick with my stock wheels? im thinking of getiing either maxxis bighorns or the maxxis buckshot, they seem to be good tires. what do you all think?
post #5 of 7 Old 03-11-2010, 09:30 AM
muddy93
2009 JK Wrangler
If you want to keep the stock rims, the big thing will be the tire width. you could run a 33" tall tire if you wanted, as long as the tire isn't to wide for you rims.
although they measure a little smaller than what's on the sidewall, I have 33x12.5's on my YJ with 3" of lift.
I do have different wheels though, and TJ flares.
Red 2009 JKU. Needs a little TLC, but it's got good bones, and will be a nice family project.
muddy93 is offline
post #6 of 7 Old 03-11-2010, 10:19 AM Thread Starter
DeepBlueJeep
Ok thanks. So now I just need to decide on what tire I want to get. Does anyone have the maxxis bighorn or buckshot? Any thoughts are greatly appreciated.
post #7 of 7 Old 03-12-2010, 06:30 AM
Happy Joe
Just as important as the lift is the axle gearing... It, too, needs to match the tire size to maintain acceptable on and off road performance. Look for a set of diffs from a 4 cylinder (4.10 gears), they are reasonably cheap because no one wants a D30 or a D35.
Also be aware that you are approching the danger area of weakness in the D35 rear diff; they have an increassed tendancy to fail with increasing tire size (in the 33 and larger size range) if used hard, off road.
Too many people want the look but are not committed enough to do it right.
Enjoy!
'06 TJ Rubicon; seemed like a good idea at the time; had many CJs...
Happy Joe is offline
3" lift/ 16" Icon rims / Cooper Discoverer ATR's/ TIRE SIZE! flashthunder Tires & Wheels 3 01-23-2009 01:04 PM
OME suspension plus 1" body lift = what max tire size? kenn Tires & Wheels 4 04-19-2005 07:10 AM
max tire size for 8x15" rims?- no lift jeepnpilot Tires & Wheels 6 08-03-2004 04:38 PM
Rim size for 31x10.50 tire? Any pics with them on 3" lift? 4x4 XJ Tires & Wheels 2 01-20-2003 06:42 PM
TIRE SIZE FOR A 2.5" LIFT FastX Tires & Wheels 3 06-07-2002 11:23 PM
