How to reset ABS and ESP warning light??? - Page 2 - JeepForum.com
post #16 of 20 Old 09-06-2017, 07:37 PM
Dovi82nd
So I have the same issue. Did it work? My shop broke it during the regear (thats the only time i take it in) and they claim to have replaced it but its still acting up. Do I need to flash it or should I try putting a new one in and it will work automatically?
Dovi82nd is offline
post #17 of 20 Old 09-07-2017, 07:11 AM
cranbiz
cranbiz's Avatar
Get a scanner that can read ABS, Harbor Freight sells one that's regularly $100, then you know which one to chase. If the shop was a bit liberal with anti seize, that can affect the new sensor and cause the ABS code. Pull the code, then pull that sensor and clean it. Reinstall it and see if the code goes away. Or you can just buy another one, they sell for $15-$30 depending on where you get it and if it's front or rear.
06 KJ
12 JK, 2.5" Teraflex lift, Bilstein 5100's, BFG KM3's 37x12.5/R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #18 of 20 Old 08-05-2019, 11:30 AM
brandenm1
Originally Posted by Vin View Post
What were you doing before they turned on. There are a few reasons why they turn on. Is your steering wheel strait? Did you lift your rig? Do you have cruise control and does it work? Did you install an sPod recently?
I changed my front and rear brake pads on my jeep wrangler 2013 and my abs and traction control lights come on. How do I reset it?
brandenm1 is offline
post #19 of 20 Old 08-05-2019, 02:27 PM
cranbiz
cranbiz's Avatar
Originally Posted by Timotb View Post
Thats interesting..... my shop suggested that was part of the whole assembly. This part is only $30. Now I have to even doubt their diagnosis of it being on the right front wheel.
Thanks
That's because the sensor comes with the unit bearing when you buy a replacement. However, you can always replace just the sensor.
06 KJ
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #20 of 20 Old 08-22-2019, 06:27 AM
samthorn
You should replace sensore.
It usualy costs around 20$.
My
. Garage owner. Based in London.
samthorn is offline
