How do I load a non-running Jeep onto a rental haul trailer. Tires have air. - JeepForum.com
 2Likes
  • 1 Post By TSEJEEPERS
  • 1 Post By RARECJ8
post #1 of 11 Old 05-17-2020, 01:07 PM Thread Starter
ITACUD
ITACUD's Avatar
Any advice on how to load up a Jeep onto a trailer. Jeep not running.
Iím officially the owner now, just need to get it home.
ITACUD is offline
post #2 of 11 Old 05-17-2020, 01:48 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Get a come-along at any hardware store.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #3 of 11 Old 05-17-2020, 06:35 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
You could get a half dozen guys to push. [Hint, pushing on the top of a tire cuts the needed force in half.]
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #4 of 11 Old 05-18-2020, 05:03 AM Thread Starter
ITACUD
ITACUD's Avatar
I have a come a long I can try. Maybe pull it out onto harder ground first with the truck. I thought about putting a battery in and using the starter in low gear to turn engine over and walk it up there. . I heard that trick but never tried it.
ITACUD is offline
post #5 of 11 Old 05-18-2020, 06:55 AM
Pcoakley5
Pcoakley5's Avatar
I moved a dead Cherokee one time by backing my Wrangler up to it and pushing in reverse with the spare tire as a buffer.
Pcoakley5 is offline
post #6 of 11 Old 05-18-2020, 11:37 AM
jay-h
That works. I've pulled vehicles into my garage that way.
Strongly recommend NOT to try to push with another vehicle. Too easy to slip and damage both of them.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #7 of 11 Old 05-20-2020, 08:36 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
I have done this with a dead vehicle in a mud hole. Assuming you have a manual transmission, it should work.
push the Jeep up the ramps as far as you can, put it in 1st, and start cranking. Don't run the starter longer than 15 seconds at a time.
You may need to bypass any clutch/starter bypass switch.
Paperwork will ruin any military force.
Chesty Puller
jeepdaddy2000 is offline
post #8 of 11 Old 05-29-2020, 06:27 PM
TSEJEEPERS
TSEJEEPERS's Avatar
KISS Pull it on the trailer with another vehicle.
Yes the trailer will have to be hooked up.
OCDXJ likes this.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #9 of 11 Old 09-20-2020, 11:01 AM
GaTechTJ
GaTechTJ's Avatar
+ one for the come-along.
Every act of kindness creates a ripple with no logical end. Scott Adams
GaTechTJ is offline
post #10 of 11 Old 09-21-2020, 11:14 PM
RARECJ8
RARECJ8's Avatar
1981 CJ8
Call Uncle Sam?
GaTechTJ likes this.
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #11 of 11 Old 09-29-2020, 09:25 PM
OCDXJ
OCDXJ's Avatar
That's the way I've always done it, just watch the fenders on the trailer with tow rope.
01' XJ, 4.0l, AW4, NP231, D30, CHY8.25, 1.5 RC lift, 245/70R16 Nokian Rotiiva AT
OCDXJ is offline
