How to clean up Muddy carpet - JeepForum.com
post #1 of 18 Old 03-15-2015, 08:08 AM Thread Starter
Thegdog
I did a dumb thing yesterday and got my jeep sideways in a mud hole. Passenger side capet was standing muddy water. Wasn't super deep but a big puddle.
I took it to the DIY carwash. Tried to Vacuum up the mud. Then did shampoo and carpet cleaner, then Vacuum. I seems like I got the mud out, capet looks clean, but still pretty wet. Right now its covered in two rolls of heavy duty shop towels. Any suggestions on what to do?
I might end up just cutting out the carpet there and putting something in place of it.
Thegdog is offline
post #2 of 18 Old 03-15-2015, 08:49 AM
gregstudeny
2006 WK
Hair dryer, heat gun, fan, run over it to press the water out, or buy new ones. I suggest weathertech
gregstudeny is offline
post #3 of 18 Old 03-15-2015, 09:14 AM
dwilliams35
Cut it out, throw it away, replace with Bedliner.
Then get your head on straight; sideways in a mud hole isn't "a dumb thing", It's a "good start"...
dwilliams35 is offline
post #4 of 18 Old 03-15-2015, 09:27 AM
zillla
1930 VJ
+1. None of my off road vehicles have carpet.. My 2 GM trucks do and it is a PITA to clean.. My old truck had rubber floor and was much easier to maintain.. I wish this was still an option.. You might try some of that carpet cleaner in a pressurized can that has a brush attached..
Pull my finger
zillla is offline
post #5 of 18 Old 03-15-2015, 09:37 AM Thread Starter
Thegdog
You say that, but look at what I did.
Thegdog is offline
post #6 of 18 Old 03-15-2015, 10:14 AM
jeepster93
jeepster93's Avatar
The 1st thing is...Wait until it drys. Nothing can be done to wet carpet. You can do things to help it dry faster, but let it dry.
Then after it drys, clean it, it will work much better.
(I own a carpet cleaning business.)
jeepster93 is offline
post #7 of 18 Old 03-15-2015, 10:38 AM Thread Starter
Thegdog
Originally Posted by jeepster93
The 1st thing is...Wait until it drys. Nothing can be done to wet carpet. You can do things to help it dry faster, but let it dry. Then after it drys, clean it, it will work much better. (I own a carpet cleaning business.)
Did I wrong vacuuming the mud puddle out?
Thegdog is offline
post #8 of 18 Old 03-15-2015, 10:49 AM
jeepster93
jeepster93's Avatar
It's gotta dry. So you need the water and mud gone for that to happen. Spray it down with a garden hose if needed. do what you need to do to get the mud out. But the clean, the appearance/smell part, that waits until the it drys.
My YJ has plastic floor plugs in drain holes in it for this exact thing.
A several step process
Get the whatever out.
Let it dry
Clean it.
This is how coffee is removed, wine, pet stains, a 3 step process.
post #9 of 18 Old 03-15-2015, 10:59 AM Thread Starter
Thegdog
It's gotta dry. So you need the water and mud gone for that to happen. Spray it down with a garden hose if needed. do what you need to do to get the mud out. But the clean, the appearance/smell part, that waits until the it drys. My YJ has plastic floor plugs in drain holes in it for this exact thing. A several step process Get the whatever out. Let it dry Clean it. This is how coffee is removed, wine, pet stains, a 3 step process.
understood! Thank You
Thegdog is offline
post #10 of 18 Old 03-15-2015, 11:43 AM
GilaMtnJeep
GilaMtnJeep's Avatar
I've rented the Rug Doctor with the hand attachment in the past. In the areas the tool couldn't get I've attached a regular hose and crevice tool. When I've done that I used quality cleaner. The Rug Doctor will extract an amazing amount of water and putting hot water in the tank helps lift the dirt and allows it to dry faster. Clean, dry, and not smelly when finished.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #11 of 18 Old 03-15-2015, 05:23 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Coin-up car wash, easy-peasy. Hang the carpeting from the clips on the wall in the stall and use the high pressure soapy sprayer with a little brush action if needed. Rinse with the high pressure rinse and they should look good as new so long as your mud isn't the kind that stains.
Jerry Bransford is offline
post #12 of 18 Old 03-15-2015, 09:57 PM
dwilliams35
like I said, a good start.
post #13 of 18 Old 03-15-2015, 09:59 PM
dwilliams35
"Carpet delete" is still an option on fords anyway, mine has the rubber/plastic floors. Can't beat it....
post #14 of 18 Old 03-15-2015, 10:36 PM
zillla
1930 VJ
Might have to look at Ford as my next vehicle.. Truck that is. I hate carpet in a truck or Jeep
Pull my finger
zillla is offline
post #15 of 18 Old 03-16-2015, 02:27 AM
karlo
+1 on using bedliner when doing off-roading. Mush easier to maintain and clean.
karlo is offline
