Harbor Freight vs Costco Portable 12v Air Compressor - In Depth Review w/ Pictures - Page 16 - JeepForum.com
post #226 of 407 Old 03-08-2008, 03:24 PM
jerryjeeper
Great article and I like the pictures. I found the Q-Max air compressors on Ebay for an average of $24 ( I bought 4). The reason I liked the Q-Max was the size and adaptability. It was used for an on board air set up in a YJ and was combined with a small surge tank from a Campbell Hausfeld repair shop. With the preset pressure switch in the tank the compressor maintains 105 psi in the tank and refills at the 70 psi range. The system is quiet and compact. I might be able to send pictures to anyone interested. Total project cost was about $90 with all the fittings and hose.
jerryjeeper is offline
post #227 of 407 Old 03-08-2008, 06:39 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
A pressure switch is nothing more than a simple on-off switch wired in series with the power wire leading to the compressor. Mine closes the circuit at 85 psi to turn the compressor on, then opens the circuit at 120 psi to shut the compressor off.
Jerry Bransford is offline
post #228 of 407 Old 03-09-2008, 09:37 AM
Mr_McNasty
Mr_McNasty's Avatar
How do I make that setup? That sounds sweet.
Also, I want to mount it under my hood like in the pictures in the thread, but I had a few questions about it. I'm pretty sure mud and water would get to it, but would it trash it? I think so. My other question is how would I get the air to my tires? Should I run a huge a$$ coil line, or split it off and run on line to the back through the cab?
Mr_McNasty is offline
post #229 of 407 Old 04-03-2008, 09:34 PM
.Jch.
.Jch.'s Avatar
Got the qmaxx masterflow for $20 on ebay. Just came in today. Can't wait to use it next week.
_____
l JEEP l
OllllllllO
2006 Unlimited
Black Jeep Club V2.0 Member #2006
.Jch. is offline
post #230 of 407 Old 04-03-2008, 10:05 PM
STW
Anybody succeeded in mounting one of these on the driver's side battery tray? I managed to fit mine in their once so I know it would fit--barely. Haven't decided how to fasten it down, though.
2000 2.5 TJ, 5spd, 33s, 8274
STW is offline
post #231 of 407 Old 04-03-2008, 11:06 PM
.Jch.
.Jch.'s Avatar
remove the feet and screw it down? And maybe to reduce any noise/vibrations put a small sheet of rubber between the tray and bottom of the compressor.
_____
l JEEP l
OllllllllO
2006 Unlimited
.Jch. is offline
post #232 of 407 Old 04-03-2008, 11:27 PM
Gabe
Gabe's Avatar
no rubber needed. this thing is that quiet. I mounte dit here, and no vibrations whatsoever
Originally Posted by Rubi22
Holy ****, did someone log onto Mean Fish's account and say something thoughtful?
Gabe is offline
post #233 of 407 Old 04-04-2008, 12:22 AM
.Jch.
.Jch.'s Avatar
how do you have it wired to the battery from there? Can't decide if I want to mount mine or not.
_____
l JEEP l
OllllllllO
2006 Unlimited
.Jch. is offline
post #234 of 407 Old 04-04-2008, 08:27 AM
STW
Was thinking also about vibrations and bouncing from the Jeep harming the compressor. If I bolt it down, don't I need some kind of rubber isloator between the compressor and the Jeep?
One reason for me to mount it is that it'll always be there. Never know when I'm going to need it. Do you all think it's durable enough to ride around under the hood for a few years? Should I cover it it with something to keep mud and dust off?
STW is offline
post #235 of 407 Old 04-04-2008, 08:36 AM
.Jch.
.Jch.'s Avatar
my thought for a rubber isolator is with the feet being removed if its bolted down against metal unless its really tight theres bound to be some sort of rattle. But if its bolted down in the tub and there is carpet or anything in the back it'll be fine.
_____
l JEEP l
OllllllllO
2006 Unlimited
.Jch. is offline
post #236 of 407 Old 04-04-2008, 10:41 AM
AdamB
I just purchased one from amazon a minute agao. A guy had one the last time I went weeling and used it to air up a flat tire after the schraeder valve core shot out while airing down. It did a 33" tire in no time at all.
2001 TJ 33's, Locker, stinger, winch.....
AdamB is offline
post #237 of 407 Old 04-04-2008, 01:32 PM
Stout95YJ
does that hose reach well to all 4 tires?
Stout95YJ is offline
post #238 of 407 Old 04-04-2008, 05:08 PM
.Jch.
.Jch.'s Avatar
Just tested mine out, worked really well. Used it to air down a tire then air it back up, didn't take more then a couple minutes to go from about 12 to 30 psi on a 33x10.50.
_____
l JEEP l
OllllllllO
2006 Unlimited
.Jch. is offline
post #239 of 407 Old 04-04-2008, 06:20 PM
Gabe
Gabe's Avatar
Even further. the carpet under my mounts provides extra cushioning as well. I didnt want to mount it under the hood in order to keep it away from water and the elements. I doubt it would last long if it was under the hood, with the heat and moisture. I extended the existing wires and used battery terminals in place of the alligator clips and ran it back through the firewall. i do need a replacement hose because i let mine get too hot and it busted. i just used some self-tapping screws through the carpet and wheel well
Gabe is offline
post #240 of 407 Old 04-04-2008, 08:41 PM
kc7yrs
kc7yrs's Avatar
If you're looking for mounts to cushion the vibrations try shock bushings - I purchased some at a local autoparts store and they worked great as a buffer.
Bob
kc7yrs is offline
Question About The Harbor Freight Coil Spring Compressor Nick B General Jeep & Off-Road Equipment 22 10-11-2009 07:37 PM
Harbor Freight cs1094 General Jeep & Off-Road Equipment 35 02-15-2007 07:56 AM
Harbor Freight ? TJ_with_Tusks General Jeep & Off-Road Equipment 2 12-25-2006 02:41 PM
Harbor Freight air compressor HeavyMetal General Jeep & Off-Road Equipment 4 02-24-2006 05:34 PM
PORTABLE 8,000 lb. WINCH Harbor Freight JEFFP General Jeep & Off-Road Equipment 10 12-23-2004 02:41 PM
