GoTreads, are they worth it? - JeepForum.com
post #1 of 5 Old 07-10-2021, 07:48 AM Thread Starter
Nick Schild
Hi, I'm considering moving to the beach that allows driving. Does anyone have experience with the GoTread recovery gear that is plastered all over Facebook? I like that they are foldable and stow away vs the long ridged boards.
Nick Schild is offline
post #2 of 5 Old 07-10-2021, 08:44 AM
222Doc
222Doc's Avatar
I wheel sand at Sand Hollow. Place has two things Sand stone like Moab and HUGE dunes of sugar sand that is very soft at times. No one i have seen/been with and that is a lot have those? Adds are directed by what you look for. Might even be from what you say if any device that can can? So if I start looking for say anything today? when i am at any other web page those adds will what I see on those pages.
So its not like because they have an add everyone uses these. If alone it is a viable idea, though if you had a winch it can do more. sand anchor can be a tire if push come to shove. You need shovel. They make sand/dirt anchors as well. they are heavy. Like a plow blade that digs in.
beach sand tends to be flat and not like Dunes. Air down means you have a air supply? air down even on stock tires is 10 psi Max. That alone will do more then anything else. From there its driver really. Sand at times you need some momentum when its soft and you going up and down and over its like being at sea. Some waves you can not do its to steep and loose( well with 500+ HP maybe ) so you have navigate around the tops. Burn a ton of fuel playing out there.
222Doc is offline
post #3 of 5 Old 07-18-2021, 08:12 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
X2 on airing down.
We do a TON of riding at the Oregon dunes and have been out in the open sand with everything from an F350 to a Honda Civic. Street pressures require a large head of speed to get anywhere in the loose sand. If you're on the beach and stay down near the surf line, the sand is usually hard enough to carry wider tires without airing down.
For a leisurely spin in the sand, airing down til you get a small "pooch" in the sidewall will get you just about anywhere you want to go. The bigger the pooch, the better the traction.
We use compressors or a slow trip to town to air back up, however, I've been investigating a Co2 tank for this purpose, which would allow quicker air ups, negate the need for heavy compressors, and help fix on the sand flats on the quads and rails.
On a side note, I've seen folks drag triple axle fifth wheel toy haulers out into the open sand with no issues. While I don't have the cajones to try this, sand movement is possible with rigs that boggle the mind.
Paperwork will ruin any military force.
Chesty Puller
jeepdaddy2000 is offline
post #4 of 5 Old 07-21-2021, 10:13 AM Thread Starter
Nick Schild
Thanks for the input. I think I should be fine as long as I air down. I carry a portable dual piston compressor anyway, which will help. As for the guy with a trailer, does the trailer need to have wide contact tires or do you air those down as well? It seems kind of counterintuitive to create more drag on tires that are not doing the work.
post #5 of 5 Old 07-21-2021, 08:07 PM
jeepdaddy2000
1971 CJ5
I stopped and talked to them ('cause I had to know) and all they did was air down the trailer tires and everybody (there were four of them) stopped on flat sand or a slight downhill in order to get moving easier.
Some picts of dunefest and sandfest( Horsfall and Winchester bay) jsut to give you an idea of what folks are dragging out there.
Chesty Puller
