Flat towing Grand Cherokee - JeepForum.com
post #1 of 7 Old 06-01-2020, 05:59 PM Thread Starter
RogerDBWorks
I have a 2020 Grand Cherokee Limited 4X4. I would like to know if I can keep the vehicle locked while flat towing.
RogerDBWorks is offline
post #2 of 7 Old 06-02-2020, 02:38 PM
gspfunk
gspfunk's Avatar
2019 WK
I don’t see why not. Double check the manual, but whether it’s locked or not shouldn’t affect anything.
19 Sting-Gray WK2 Trailhawk | Hemi | MRR | Ridge Grapplers
08 Silver WK1 SRT8
gspfunk is offline
post #3 of 7 Old 06-03-2020, 01:13 PM
cranbiz
cranbiz's Avatar
Why couldn't you?
You flat tow a WK2 with the transmission in park and the transfer case in neutral. You need to push that little tiny button behind the dial selector to put the t case in neutral. Once that's done, there is no need for the fob to be in the vehicle.
I'm assuming your Limited has QTII?
06 KJ
12 JK, 2.5" Teraflex lift, Bilstein 5100's, BFG KM3's 37x12.5/R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #4 of 7 Old 06-03-2020, 09:46 PM
rjbruzan
You need 2 sets of keys. The steering must be unlocked so it can turn. The second set so you can get into the locked vehicle.
Ron
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #5 of 7 Old 06-04-2020, 09:36 AM Thread Starter
RogerDBWorks
Thanks, Ron. I did not see anything in the Owners' Manual about unlocking the steering column. Other vehicles I have towed required putting the ignition in the ACC position although it was not necessary for my 2008 Wrangler Sahara.
I would appreciate any further advice.
Thanks,
Roger
post #6 of 7 Old 06-04-2020, 09:38 AM Thread Starter
RogerDBWorks
Thanks for the response. Yes, my Limited has QTII. What an amazing vehicle!!
post #7 of 7 Old 06-04-2020, 10:03 AM
cranbiz
cranbiz's Avatar
Ron
Ah, no. At least on a 2020 WK2 (and my 17 as well). They are push button ignition. No column lock.
06 KJ
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
