Filling tires with paintball air tank? - Page 2 - JeepForum.com
post #16 of 21 Old 01-24-2009, 10:27 AM
frhrwa
Fish'n Fool
frhrwa's Avatar
I"ve got one of the spark plug fillers also, and they do work, more trouble than the hose to the tires trick, but depending on how far you are from a service station ( I use "service" loosely, since Service STations quit giving service years ago!), anyway, the hose will get you out and back to Civi....
frhrwa is offline
post #17 of 21 Old 01-26-2009, 03:59 PM
oxiderush
i was just at harbor freight tools, and thay have a system to use paintball tanks to run samll airtooks like nail guns. It's 45 bucks, but it's the perfect thing to use, just add a air chuck on a make quick disconnect and plug it in.
oxiderush is offline
post #18 of 21 Old 01-26-2009, 07:40 PM
Scotch740
Scotch740's Avatar
Originally Posted by PILL View Post
I'm not sure about 4x4 CO2 setups, but those in paintball don't usually use a regulator, but just a valve. The tank is a 4500PSI 70ci high pressure air tank. Can anyone do the math and see if I could air up tires with it? I have 31in BFG AT's
Simple assumptions
PV=MRT
Pressure*Volume=Mass*R*Temp
Since M R and T remain constant...
P1*V1=P2*V2
V1=70ci
Assume cylindrical tire
V2=pi(wheel R^2 - Rim R^2)*wheel width + volume of tank
=3.14(15.5^2-7.5^2)*10.5+70
V2=6140ci
So to find the volume that tank would fill from 0-30 psi
4500PSI*70ci=30psi*volume ==> Volume= 10500ci
10500/6140 = 1.7 tires from 0 to 30 psi.
Probably money spent better elsewhere.
Scotch740 is offline
post #19 of 21 Old 01-26-2009, 08:55 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
All the above comments say at worst you will die, and at best you should spend money to regulate that tank. You only have 31" tires. Go spend that regulator money on a simple electric air compressor and move on. Save the paintball tank for paintball.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" Patagonia M/Ts, AX15, NP231+4:1+SYE+2LO, York OBA.
Web Admin for
JeeperDon is offline
post #20 of 21 Old 01-27-2009, 08:54 AM
mylt1
mylt1's Avatar
+1. an electric pump from pepboys is what a friend of mine uses and it works just fine. i use an old SCBA tank since i got it free. all i had to do was use a wielding regulator modded to fit the tank.
mylt1 is offline
post #21 of 21 Old 01-29-2009, 09:20 AM
tuck
looks like nitrogen tank from when i used to paintball. be careful with all that pressure. i had a friend that screwed himself up pretty good playing with his regulator
tuck is offline
Paintball tank! satansmurf Tires & Wheels 14 03-21-2013 01:17 PM
Paintball air tank to fill tires? heepyjeepy General Jeep & Off-Road Equipment 29 03-18-2009 10:32 AM
OBA Crazy Idea PAINTBALL Pipedrummer General Jeep & Off-Road Equipment 21 04-18-2007 09:48 PM
20oz paintball tank to fill tires. jsjeep98 General Jeep & Off-Road Equipment 7 01-22-2007 10:26 AM
Paintball CO2 Cylinders Rodimus General Jeep & Off-Road Equipment 12 12-09-2006 02:22 PM
