Engine Snorkels - JeepForum.com
post #1 of 8 Old 03-23-2002, 11:21 PM Thread Starter
evilpsych
evilpsych's Avatar
Engine Snorkels
K guys.. who else makes these other than ARB/OME? also does anyone have a link to a homemade jobby?
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #2 of 8 Old 03-24-2002, 08:08 AM
osburn
osburn's Avatar
Personally, I never would have even considered a snorkle because they are so obnoxious looking and I don't really need one. But, this changed my mind.
<a href="http://www.darksiderz.co.uk/technical/humsnork/index.htm" target="_blank">http://www.darksiderz.co.uk/technical/humsnork/index.htm</a>
I think it could be done far less expensive, but no matter what, this is the best looking job I've seen.
Here's another much less expensive snorkle.
<a href="http://www.hopkinsherald.com/sirJeep/slides/display.cfm?sid=8&s=i&RequestTimeout=500" target="_blank">http://www.hopkinsherald.com/sirJeep/slides/display.cfm?sid=8&s=i&RequestTimeout=500</a>
Matt Osburn
Score 1032
osburn is offline
post #3 of 8 Old 03-24-2002, 11:02 AM
mikeythefireman
mikeythefireman's Avatar
That is the best looking snorkel I have seen. Looks very professional when done. Osburn, did you do this to your Jeep? If so, did you find a way to do it cheaper?
Just Sayin'
mikeythefireman is offline
post #4 of 8 Old 03-24-2002, 11:03 AM
mikeythefireman
I am obviously referring to the first link, the Hummer snorkel. Thanks.
Just Sayin'
post #5 of 8 Old 03-24-2002, 11:26 AM
osburn
osburn's Avatar
Nope, I haven't done this. But it would seem you could use less expensive components. Matter of fact, use the components from the second link and just locate it like the first link.
Matt Osburn
Score 1032
osburn is offline
post #6 of 8 Old 03-24-2002, 08:02 PM
mikeythefireman
Makes sense. There really is no need for a new air filter,either. I would haveta get the Hummer cap though, thats the coolest part. Not so much cause its from a Hummer, but its so clean looking, like it belongs.
Just Sayin'
post #7 of 8 Old 03-27-2002, 07:16 PM
big blue TJ
I think I like the ARB because you will die before the engine does
98 Tj 2" Teraflex, 31" BFG M/T K/M, Airraid, T-body spacer, Gibson cat back 3", H-4 upgrade with PIAA super whites, 100 w lightfore, Ramsey 8000 plus
big blue TJ is offline
post #8 of 8 Old 03-27-2002, 09:28 PM
RodeoRob
RodeoRob's Avatar
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by big blue TJ:
<strong>I think I like the ARB because you will die before the engine does </strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">ummm... not unless you do a lot more waterproofing or you've got a diesel under the hood!
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
Snorkels 'suck'? Savage4x4 Engines & Drivetrain 9 10-27-2003 07:27 PM
snorkels??? cherokeexj1994 Engines & Drivetrain 2 08-05-2002 03:10 AM
Snorkels LittleCj5 General Jeep & Off-Road Equipment 2 05-15-2002 08:46 AM
