Eliminate interior odor - JeepForum.com
post #1 of 12 Old 04-11-2011, 07:09 PM Thread Starter
VinceF
I spilled a small amount of milk in the back of my wrangler during the winter and through I got it cleaned up. Now that it is starting to get warm it is starting to smell.
Any suggestions on how to get the smell out short of removing some of the carpet?
Thank you
VinceF is offline
post #2 of 12 Old 04-11-2011, 08:54 PM
duckman1
Find an enzyme based carpet cleaner and keep cleaning over and over and over.
Duckman1
duckman1 is offline
post #3 of 12 Old 04-11-2011, 09:00 PM Thread Starter
VinceF
Thanks,
I sprayed my first application of that type of cleaner and also put a bowl of baking soda in the area to see if that will help. Where the problem is in that little area near where the tire jack is stored.
VinceF is offline
post #4 of 12 Old 04-14-2011, 05:25 PM
DubJ
Yea arm and hammer sells a little frige pack of baking soda. I keep one under my seat to catch any stench. They also sell powders that you put in your carpet and leave in for like 30 mins then vacuum. It smells fresh for a couple months after that. A mix of the two should make it somewhat easier on your nose
01 WJ - 3" IRO
DubJ is offline
post #5 of 12 Old 04-14-2011, 11:22 PM Thread Starter
VinceF
I have tried the cleaner and baking soda for the last few days now and I don't think I am having much luck. I think I may have to cut the offending section of carpet out as much as I hate to do it.
VinceF is offline
post #6 of 12 Old 04-14-2011, 11:41 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I'd first take the offending piece of carpet out and sic the high pressure soapy spray on it from the local coin-op carwash, then rinse it good and let it dry in the sun. At the most, after doing that, perhaps a little Lysol or Febreeeze to spray down the rest of the interior to get rid of any remaining odor.
Jerry Bransford is offline
post #7 of 12 Old 04-15-2011, 01:45 AM
scavanau
Remove bacteria = eliminated odor. You need to sanitize.
scavanau is offline
post #8 of 12 Old 04-15-2011, 10:25 AM
BlackBellamy
BlackBellamy's Avatar
Yeah, you don't need to cut your carpet - it comes out. Take out the offending piece, dunk it in some antibacterial cleaner, then hose it down real well and leave in the sun to dry.
The top and doors on this vehicle are designed only for protection against the elements. Do not rely on the top and doors to contain occupants within the vehicle or to protect against injury during an accident. Wear seatbelts at all times.
BlackBellamy is offline
post #9 of 12 Old 04-15-2011, 12:00 PM Thread Starter
VinceF
I am still working with the Baking Soda for another day or so then I will go on to something else. I will check and see how the back carpet comes out. If the baking soda doesn't work then I will attempt the spot power wash on the small piece.
Thanks to al for your suggestions. No more milk products in my jeep unless it is triple bagged.
VinceF is offline
post #10 of 12 Old 04-19-2011, 01:46 PM
JeepinSoldier
Clean the area as previously posted, then take the Jeep to an auto detailer with an ozone machine. They run the machine for several hours and it takes out the smell.
We just purchased a 2000 WJ for our 17 year old daughter. Perfect condition, low mileage, one owner Jeep. $4,500! However - the previous owner was a smoker. You opened the door and the smell knocked you over LOL.
We took it to the detailer who cleaned the inside then ran the ozone machine for about 5 hours. This included 30 minutes of idleing with the A/C on and set to interior recirculate to get the smell out of the A/C and vent system. The Jeep smells great now!
The detailer claimed the machine would also take out smells like spoiled milk, rotten food, dead small animals, etc.
2005 Bright Silver Jeep Wrangler Unlimited Rubicon. Dual tops.
JeepinSoldier is offline
post #11 of 12 Old 04-19-2011, 11:23 PM Thread Starter
VinceF
I will check around and see if someone around here as an ozone machine. Maybe I will get lucky. Right now I can't set the carpet in the sun because I haven't seen the sun here for about a week. A lot of cold and rain.
I will let you know what happens when I finally get the smell out.
Thanks again.
VinceF is offline
post #12 of 12 Old 04-20-2011, 05:27 PM
DubJ
Well plan b...rip it out and spray bedliner!
01 WJ - 3" IRO
DubJ is offline
Things that reduce or eliminate death wobble CB3 Tires & Wheels 1 07-06-2010 12:36 AM
Eliminate my EGR valve? Calebster Engines & Drivetrain 3 11-15-2008 09:15 PM
redoing the interior? JamesEric General Jeep & Off-Road Equipment 4 01-17-2006 12:26 AM
Eliminate T-case drop erickpl Tires & Wheels 1 08-26-2005 01:39 PM
