Double shear track bar? - JeepForum.com
post #1 of 3 Old 08-31-2010, 06:08 PM Thread Starter
XJcruiser
XJcruiser's Avatar
What is the advantage of a double shear track bar? I know I dont really need one for a 3 inch lift, but I do want to replace the track bar and its not that much more.
XJcruiser is offline
post #2 of 3 Old 08-31-2010, 06:32 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
A double-sheer mount has two support points, one on both sides of the joint, so it is stronger. A single sheer is supported on just one side. That said, typical track bar mounts are single-shear at the top and double-sheer at the bottom... probably just because it's not easy to go double-sheer at the top.
Jerry Bransford is offline
post #3 of 3 Old 08-31-2010, 10:08 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
whats it going on?? XJ? TJ? JK?
what brand?
some mounts advertised as double shear aren't exactly the smartest designs and introduce more problems than their worth.
IMHO, if you're going to go double shear front track bar mount on a TJ, you need to hack that cast POS off and fabricate something better. XJ's got it a bit easier from the replacement standpoint with the bolt on mount design. JK's are already double shear
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
Narrow track vs. wide track c17load83 Engines & Drivetrain 5 10-20-2010 09:20 PM
D44 double shear high steer arms. ksheffer08 Fabrication Shop 5 10-13-2009 12:21 AM
Anyone ever shear a pin in their Aussie? LandoCommando Engines & Drivetrain 0 03-02-2009 07:21 AM
I need Shear Pins!!!! For Lock Rite!!! usmctadpole Engines & Drivetrain 6 01-22-2009 09:45 PM
double double cardan? Vacant Stare Engines & Drivetrain 2 12-12-2006 04:32 PM
