Dana 44 Balljoints - JeepForum.com
post #1 of 5 Old 06-29-2011, 01:14 PM Thread Starter
TSEJEEPERS
TSEJEEPERS's Avatar
Dana 44 Balljoints
Looking for stronger ball joints for a Waggy 44.
Balistic has pretty much dropped the ball.
Synergy Suspention is saying they will produce them. Not sure when though.
Came across this on another forum. http://www.bonefishfab.com/
Anyone heard anything about this company?
Anyone running their ball joints?
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #2 of 5 Old 07-09-2011, 08:52 AM
RedlegWJ
RedlegWJ's Avatar
Bonefish looks promising, I just shot them an email requesting a WJ version. I encourage others to do the same.
RedlegWJ is offline
post #3 of 5 Old 07-09-2011, 09:18 PM Thread Starter
TSEJEEPERS
TSEJEEPERS's Avatar
I was about to say would'nt the ones from Synery Suspention work on your WJ, but I see you are planning on putting a High Pinion 44 in place of the 30.
I guess these would be for the 44?
E mail sent by the way.
post #4 of 5 Old 07-16-2011, 07:17 AM
mnhowardcat
I got a set of ball joint from BoneFish they whe'nt in easy and they work jest like a standard ball joint I'm happy with they and I dont have to wory about braking a wheel off again
mnhowardcat is offline
post #5 of 5 Old 07-17-2011, 07:49 AM Thread Starter
TSEJEEPERS
TSEJEEPERS's Avatar
How long have you had them in?
Do you wheel, where?
What axle did you put them in? (you have no profile)
Swapping a dana 20 transfer case for a dana 18 masimpson48 Engines & Drivetrain 2 12-12-2009 03:05 PM
DANA 30 outers on DANA 44 front axle-- with a twist IN8LYJP Engines & Drivetrain 1 07-08-2009 04:40 AM
chevy dana 60 balljoints dwgfd34 Engines & Drivetrain 2 06-18-2009 08:16 AM
Dana 60 axles in Dana 44 housing external hubs dustydoggy Engines & Drivetrain 1 03-26-2009 12:39 AM
Bolt in Dana 44 or Dana 60 Rear Assy - Looking for a dealer wheelinjames Engines & Drivetrain 18 09-23-2006 06:02 PM
