A/C leak problem with my 94 wrangler soft top - JeepForum.com
post #1 of 3 Old 12-02-2018, 10:02 PM Thread Starter
Fishstic
Fishstic's Avatar
I bought my Jeep a couple months ago, and everything seems to be in line, except for the fact that whenever I'm on the freeway or going anywhere above 50-60 mph a mist of condensed/vaporized water comes out of the A\C vents, eventually ice starts to form along the top edges of the vents and after a while the vents will start becoming sprinklers as droplets of water start pumping out of the vents as well. another issue that's probably related to the other one is that as this all happens water begins to drip down into the floor of the passenger seat and eventually it'll start pooling all over the floor into this small puddle. I don't have any idea what the issue could be, was hoping I could get some help here. I was thinking maybe it's the drain, as the back of the A\C section is covered in water, but I don't wanna touch anything since I don't wanna mess anything up yet.
Fishstic is offline
post #2 of 3 Old 12-05-2018, 12:32 PM
cranbiz
cranbiz's Avatar
Yup, the drain is plugged.
06 KJ
12 JK, 2.5" Teraflex lift, Bilstein 5100's, BFG KM3's 37x12.5/R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #3 of 3 Old 12-05-2018, 04:19 PM
mukluk
mukluk's Avatar
It sounds like your evaporator coil is icing up, this is usually due to low refrigerant in the system. I would advise having the system checked for leaks and reserviced.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
ac , leak , water , wrangler , YJ
