Broken Shock Absorber... - JeepForum.com
post #1 of 7 Old 06-14-2010, 03:40 AM Thread Starter
chevyx68
Tumble Bee
chevyx68's Avatar
Well, not exactly. The piece that goes thru the top eyelet and fastens to the frame broke. It turns out it's just a hollow tube with the ends pinched and slotted (I don't know if this is how all manufacturers make them or not). Would it take well to a welding or should I just make one out of solid rod?
The shock is only 2 years old and still works fine. I'm too cheap to replace just yet.
-Jim
2000 Jeep Wrangler Sport, 3" lift for playing in the dirt
2003 Jeep Liberty Limited for picking up groceries and going away on vacation
1988 Buick Regal Custom, just because
"If, at first, you don't succeed, keep on sucking 'til you do succeed!" -Curly Stooge
164,000mi and counting.
chevyx68 is offline
post #2 of 7 Old 06-14-2010, 04:48 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
You can probably knock/drill/cut out the stub of the post so you end up with a somewhat large hole in the welded on bracket. Some shock companies include bolt-on posts with their shocks, I know Rancho does with some. Here is a photo of the mount I fabricated on my Jeep, but I used the bolt-on post that came with the shocks. You may be able to get the bolt separately somewhere and use it with the OEM bracket.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #3 of 7 Old 06-14-2010, 06:37 AM Thread Starter
chevyx68
Tumble Bee
chevyx68's Avatar
That's a nice mount you have there, but I think we have very different setups. On my TJ, the top of the shock gets bolted to the bottom of the frame. I TIG welded the part, and hopefully it'll hold up. It just surprised me that Black Diamond/Superlift would use cheesy materials like a hollow tube for their shock mounts.
-Jim
chevyx68 is offline
post #4 of 7 Old 06-14-2010, 08:14 AM
JeeperDon
JeeperDon's Avatar
Sorry. I usually notice the vehicle type but missed it this time. Yup, very different, and a much easier fix than if the post had broken of a YJ.
Web Admin for
post #5 of 7 Old 05-22-2014, 10:53 AM Thread Starter
chevyx68
Tumble Bee
chevyx68's Avatar
Four years later, and the weld job has held for twice as long as the part did before it broke.
-Jim
chevyx68 is offline
post #6 of 7 Old 05-22-2014, 11:18 AM
strvger01
1966 CJ5
sounds like you did a great job welding it up. congrats!
1966 CJ5A, mods are coming
1966 Wagoneer, bone stock
strvger01 is offline
post #7 of 7 Old 05-24-2014, 05:16 PM
Feetwet
Enjoying the Ride
Feetwet's Avatar
Way to post an update!!
Fight Crime...Shoot Back
Friends don't let friends roll over without a negative-G strap
Feetwet is offline
Broken Bracket Rear Shock. Need ADVISE! D33COFF3Y General Jeep & Off-Road Equipment 1 05-17-2010 02:43 PM
Shock absorber assembly falco84 General Jeep & Off-Road Equipment 8 06-14-2009 08:22 PM
Shock Absorber Fit JeepX89 Tires & Wheels 2 04-12-2008 03:47 PM
Rear Shock Upper Mounts - Broken bolts Wifs'98XJSport Tires & Wheels 6 01-09-2008 07:58 PM
Shock Absorber (poll) Death-Mobile Tires & Wheels 3 01-06-2005 05:38 PM
