Bolt-together fiberglass Jeep-tub trailer kit - Page 236 - JeepForum.com
 16Likes
post #3526 of 4307 Old 04-01-2014, 06:13 PM
SSRx7
Hey Jeff, I was just thinking that you could build a front storage box with your Trail top prices... To match the rest of the trail top.
SSRx7 is offline
post #3527 of 4307 Old 04-01-2014, 06:30 PM Thread Starter
jscherb
Yes, you definitely could do that, a storage box would be easy to build with TrailTop parts.
If you're building on a Jeep tub like I'm doing for the proof-of-concept build, of course the ultimate matching storage box would be made from a combination of Dinoot parts and TrailTop parts ...
"Whether you think you can do something or you think you can't, you are right" - Henry Ford
jscherb is offline
post #3528 of 4307 Old 04-02-2014, 06:13 AM Thread Starter
jscherb
I haven't decided yet if I'm going to support the hatch in the open position with gas struts or a more simple prop rod of some sort. For now in the workshop I'm using a stick:
Since this is a proof-of-concept build, I'm thinking I should do gas struts to prove how they would work with the TrailTop parts, but I'd welcome any input you guys have on hatch supports.
jscherb is offline
post #3529 of 4307 Old 04-02-2014, 07:08 AM
wwch99tj
wwch99tj's Avatar
Gas struts would be nice but I'd think a prop rod would be just fine.
Sent from my Samsung Galaxy S3 using JeepForum
wwch99tj is offline
post #3530 of 4307 Old 04-02-2014, 07:29 AM
Sundowner
Sundowner's Avatar
I'd use gas struts, personally; it's a more finished, clean appearance and the struts offer a bit of lift assistance.
Sundowner is offline
post #3531 of 4307 Old 04-02-2014, 08:17 AM
R3dRid3r
I'd use gas struts for a more finished look but more importantly, if anyone else is as clumsy as I am I'd be bumping into the prop when entering and leaving.
"You'll Shoot Your Eye Out"
R3dRid3r is offline
post #3532 of 4307 Old 04-02-2014, 08:54 AM
SSRx7
I like the factory supports on my cj hard top. They are springs inside metal tubes and very strong. Only problem would be where to get them for a build.
SSRx7 is offline
post #3533 of 4307 Old 04-02-2014, 09:20 AM Thread Starter
jscherb
I've got a pair of those old CJ hardtop ones here, but it's probably not a good idea to use them on the proof-of-concept because as you said, where would anyone get ones like them?
jscherb is offline
post #3534 of 4307 Old 04-02-2014, 09:54 AM
SSRx7
The hydraulic ones would be my next choice but are there any out there that don't fail after a while?
Of course you could also use the electric ones that are so popular these days but those would be more costly and complicated to install. But it is an option.
SSRx7 is offline
post #3535 of 4307 Old 04-02-2014, 10:33 AM Thread Starter
jscherb
Here's a quick drawing showing how struts would mount. It's pretty straightforward:
jscherb is offline
post #3536 of 4307 Old 04-03-2014, 09:09 AM Thread Starter
jscherb
Yesterday I went to my local U-Pull junkyard to shop for some gas struts for the hatch. My SWAG engineering suggested I would find appropriate struts on a full-size SUV with a separate tailgate and lift glass in the back. I figured a lift glass with a metal frame would probably weigh just about as much as the hatch and have about as much leverage. I grabbed a pair of struts from a '95 Chevy Tahoe and they seem just about right. Here they are clamped in place as a test:
Initial tests show that these have just about the right force.
jscherb is offline
post #3537 of 4307 Old 04-03-2014, 10:03 AM
SSRx7
Hey Jeff, how well are the ends going to clear the edge in that position? I would think that the lower end would be mounted onboard of the frame and the upper ends mounted on or onboard of the hatch rails so the hatch doesn't close on it... unless this picture was to demonstrate them holding the hatch up?
Also when you mount them, would you attach them while the hatch is in the closed position? Reason being that shorter strut will not allow the hatch to open as far. You will need to have longer struts I think depending on how far You want to open it.
I just ask out of curiosity.
SSRx7 is offline
post #3538 of 4307 Old 04-03-2014, 10:15 AM Thread Starter
jscherb
Bill,
The struts will clear everything just fine; they'll bolt to the side of the curved hatch rib and to a bracket on the underside of the weatherstrip surface of the curved TrailTop frame, just like I showed a couple of posts ago when I drew struts on a photo to show how they'll mount. The most recent photo was taken when I was testing to see if they had the proper strength to support the hatch, and how much force it would take to start to close the hatch. The tests were passed just fine, these struts have appropriate force for this application.
Stay tuned, I'm working on an explanation and drawing showing how I choose a correct length and strength of struts, and how I pick the attachment points.
But don't worry, this length strut will be fine.
Jeff
jscherb is offline
post #3539 of 4307 Old 04-03-2014, 10:18 AM Thread Starter
jscherb
I'm pretty sure most auto manufacturers designate gas struts as "wear items", which puts them in the same category as brakes, tires, etc. They're inexpensive to replace (well, maybe not if you buy OEM ones from the dealer ). The ones I picked up yesterday were from a '95 Chevy Tahoe, I don't know if they were the original ones on the Tahoe or if they had been replaced at some point in the truck's life, but they work fine. And if they fail, it won't be expensive or difficult to replace them in the future.
jscherb is offline
post #3540 of 4307 Old 04-03-2014, 10:26 AM
SSRx7
Cool. I don't ever question you, just ask in case someone else is as curious as I am
SSRx7 is offline
Need new tailgate: Fiberglass or 'Jeep'? JeeperDon YJ Wrangler Technical Forum 3 01-29-2012 10:18 AM
Bolt on trailer hitch receiver? Scottsdale Jack TJ Wrangler Technical Forum 22 06-30-2010 08:25 PM
Those of you that trailer your Jeep. Jeeeeeeeeeeeeep YJ Wrangler Technical Forum 15 02-04-2010 08:47 PM
trailer hitch receiver bolt removal???? vosevichs TJ Wrangler Technical Forum 3 01-20-2010 07:01 AM
Bolt Size for Mopar JK trailer Hitch Fish Slayer JK Wrangler Technical Forum 13 06-08-2008 12:15 AM
